I push end to turn on the phone. it goes to the start up verizon screen then the red loading bar loads to the end then freezes and at the top of the screen it says restart flash area. i have tried plugging it into the charger and hard reset but nothing works.
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
SOURCE: Samsung SCH-a870 turning off and on
i have the same deal with the metropcs and it turns on to load and then it turns off
SOURCE: My Samsung SCH-u540 keeps turning on and then shutting off
Sounds like you have a defective battery. If you can use the phone normally with the charger plugged into it that is more than likely the problem. Step one is order a new battery. If that don't solve the problem take it into the store, but only if it's under warranty, otherwise shop for a new one.
SOURCE: Samsung SCH - U340 won't turn on
hold 9 while powering the phone up i had the same issue then i did some googling and it worked for me :D gald i could help. now refer to me as king mike bc i solved your problem :D
SOURCE: When I plug my sch-u340 into charger it turns off and wont charge
I had the same problem. after replacing the charger i no longer had any problems. dont know if it will work for you but it helped me. hope it helps you.
