Televison & Video Logo
A
Anonymous Posted on Aug 07, 2012
PANASONIC TH 50pv70mr
Panasonic TH-50PV 70MR
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Oct 05, 2008
SOURCE: Panasonic TH-50PZ Plasma TV won't come on.
what is a UPS?? mines doing it too
ripleymojica
Mando Mojica
  • 643 Answers
  • Posted on Jun 03, 2009
SOURCE: broken glass - 42 panasonic th c42hd18
usually not very cost effective to replace the front screen. id say around 70% of what you paid for the tv.
Chi Chu
  • 8457 Answers
  • Posted on Aug 13, 2009
SOURCE: Panasonic TH-42P60U turned off and wouldn't start up
Replace ur power coverter ic board is dead.
Order it in the web. or repair man repalce cost $575 part and labors.
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Jun 04, 2010
SOURCE: Panasonic Plasma TH-42PX60U, got a power surge.
www.warrantyweek.com/library/.../panasonic-th42px60u-manual.pdf Above is your user manual. http://www.eserviceinfo.com/downloadsm/39216/Panasonic_Th37-42px60u.html
Above is a multipart Service manual, please download. Below is a service manual, it's in Spansih, however there is an online Translation, to english This will help you zero in on the problem. http://www.scribd.com/doc/7581800/RCA-CTC-Chasis-175176177-TV-Training-Manual-Spanish
http://srvman.com/p8u8rouicth42p860urmrvicm28u58l-p-146.html
Above is a pay for service manual. These manuals will give you valuable understanding and information to assist you in deciding what to do.
With this symptom, it is impossible to tell what the exact "Cause" of this symptom is. The LED's do not tell us what is wrong, sometimes it may indicate the "Area" in your case it is the X board. BUT thats NOT where the "Fault is" thats just the part that is affected. These days unlike the "Old" analogue days it just isn't realistically possible to fix anything but the most basic of problems with todays sophisticated units. This is quite apart from the Safety aspect, any unit that can cause a firs or have an explosion, or both, is NOT to be treated lightly, and and the repairer, of the unit is legally responsible, another thing to think about. Also, one must have tools, a Multimeter, a soldering iron, a deslodering iron, an oscilloscope, a signal tracer, tools, and most important of all, a Service Manual, without which, there is no way to even begin to understand and fix it, and more importantly Program it, AFTER it has been fixed. As these days a TV, is a PC, a Tuner, and an HDTV Monitor, and more, all in one. in the "old" days TV"s were more, rudimentary, and built to last for 20 years, and a "Parts" supply was set aside. They usually used to fail for only a few reasons, and they while still difficult, were less difficult to repair. Electrical knowledge was transferable, and they could be and would respond to, This-is-the-symptom-This-us-the-Fix, But that no longer applies, as now, it can be a Fault on I squared Bus, or "Sensor" failure, or it simple may have "Crashed" just like a PC, It could be a Diode go bad, and that will stop the whole thing. You see, in the day, the sets were Very "Fault Tolerant" because they were Analouge, and a faulty, component, or more sometimes, the set would always diplay something usually, and when they didn't it was one of only a few things, sure there are always the horrid ones, and there are pleanty of those, but all in all it was quite easy. But with Digital Electronics, it either goes, or it doesnt, there are usualy few half measures. I mean thats the definition of logic either going or not. So it can take very little to completely paralyse a set, and generally give the only sysmptom, it can, by not working, usually No picture, or the like. So you, see the list is endless almost for any given SYMPTOM, as that is what is being seen, not the cause, as I keep going on about. Also any fault, usually involves the Power Supply, it is either the cause, the cause of the damage, or it is damaged. or ALL of them. Then after you have done the electronic repairs, you then must program the set to work, and align, and set up in general, any one of those settings missed or done wrong, back to square one. So, it is nearly always my professional opinion that one should always get a "Quote" form the manufacturers recommended service center, Panasonic, in your case. Now,I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone
  • 6688 Answers
  • Posted on Dec 26, 2010
SOURCE: How do I connect my
If you have a set top box (blu-ray, dvd, cable) with HDMI Out, then you need a pair of HDMI cables. Connect one from the HDMI Out of the set top box to the HDMI In of the sound bar. Then connect the HDMI Out of the sound bar to the HDMI In of the TV.
If you only want to use the sound bar as an external speaker system for the TV, then you should get a digital audio cable (fiber optic cable). Connect this to the Digital Audio Out on the TV (below HDMI ports) and to the Digital Audio In of the sound bar.
I hope this helps. You can find the manual of the TV here: http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-TVs/model.TH-42PX75U . The TV also has analog (RCA) audio out jacks labeled Prog Out on the bottom left of the connection panel; the sound bar however doesn't have RCA audio in jacks.
(since there are no HDMI out jacks on the TV, there is no other way to connect the sound bar.)
How do i program a device using this remote
From what I can tell the EUR7627Z60 was originally shipped with the following Panasonic products: TH-37PX50U, TH-37PX50U, TH-42PD50, TH-42PD50U, TH-42PX50, TH-42PX50U, TH-42PX50UA, TH50PX50, TH50PX50U, TH-42PD50, TH-42PD50U
Here is the manual for the Panasonic: TH-37PX50U/TH-42PX50U/TH-50PX50U:
Panasonic TH 37PX50U Operating Instructions Manual
Best of luck!
Panasonic TH50PE8U
Panasonic Product Support - TH-50PX80U
shop.panasonic.com > Get Support
PanasonicOwner's Manuals. Owner's Manuals and Documentation. Operating Instructions Manual- TH-50PX80. Warranty. Warranty information. Warranty - TV Plasma ...
Panasonic TH-50PE8U Flat Panel Television User Manual
tv.manualsonline.com > ... > Panasonic Flat Panel Television
... and free pdf instructions. Find the user manual you need for your TV and more at ManualsOnline. ... Panasonic TH-50PE8U Flat Panel Television User Manual ...
Seeking an instruction manual for TH-42P270BA
Do you mean the Panasonic TH-42PZ70BA? If so, then the manual is available from ManualsLib: http://www.manualslib.com/products/Panasonic-Th-42pz70ba-3190573.html . The manual is also available on the Panasonic Europe support site. Go here: http://www.panasonic.eu/Downloads/en_GB/popup.html and then search for the model. From there, you will need to accept the Panasonic Terms of Use (a pop-up will open) to view the manual.
I hope this helps.
Need User Manual for Panasonic Viera TH-L37X10S Lcd tv
The manual for theTH-L37X10S is available from Panasonic here: http://www.panasonic.ae/EN/Manuals/TH-L37X10A.pdf . (Note it's the same manual even though the final letter is different.) If the above link doesn't work, start here: http://www.panasonic.ae/EN/Pages/TH-L37X10.aspx and click on the Manuals tab.
I hope this helps.
2answers
I need a manual for the panasonic t.v. th 42px600e
user manuals here http://www2.panasonic.com/consumer-electronics/support/Televisions/VIERA-Plasma-HDTVs/model.TH-42PX600U
direct link to the manuals
  • http://service.us.panasonic.com/OPERMANPDF/TH42PX600U-MULTI.PDF
  • http://service.us.panasonic.com/OPERMANPDF/TH42PX600U.PDF
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
3helpful
Does anyone have a panasonic TH-42PX50U Service Manual I could download?
www2.panasonic.com/consumer.../model.TH-42PX50U
www.nodevice.com/manual/.../panasonic/th.../get29233.html
www.panasonic.user-manuals.com/list-of-manuals-292-5104.html -
You can copy and paste any of these links into your address bar to bring you to your manual
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
