Recently when I have been listening to the television through my headset (sennheisser TR115) wireless, the green light on the bass station go's out & I get an earfull of interfearance.
Now when I unplug the jack plug from the set & then put the jackplug back in,the green light comes on again & the sound is good for about 10 minutes.This has only happened recently,any ideas please.
SOURCE: Sennheiser RS 130 Wireless Surround Sound Headphones
Did you try to remove the batteries and at the same time unplug the power of the base for 30 sec ?
SOURCE: No sound coming through my Sennheiser wireless headphones
Turning the transmitter on and off (Fig. 5)
Turn on the sound source. This automatically activates the
transmitter and the green LED “ON/OFF” lights up. If the sound
source is turned off, the transmitter is automatically deactivated
after approx. 3 minutes (the LED “ON/OFF” goes off).
Note: The automatic level control only functions if the volume of the
sound source is sufficient.
SOURCE: Replacement connector for Sennheiser PX 250 doesn't work...
The bare copper conductor wire is the screening/common earth to the two signal wires of green and red. The important connection is the copper wire which goes to the jack plug earth which is the section furthest from the tip. The other two are the left and right signal connections. If you get these the wrong way round you will just have to swap them over. Check if they are the right way round by using the balance control on your amplifier or whatever. Have you checked that the problem is not with the headphone amplifier within your equipment? Don't rely on OK sound from loudspeakers as the headphones may be fed from separate op-amp output chip. Try another pair of cheap and cheerful headphones to make sure.
SOURCE: Brand new Sennheiser RS140 headphones stopped working
Mine is a bit older (2yrs), but I have exactly the same problem. Absolutely no sound from the headphones (no beeps). I also tried new batteries, but still nothing.
If you have a solution, let me know!
Tanks
SOURCE: Sennheiser Wireless Headphone Stops transmitting signal
If you're using a mac, I've made an instructable on how to make this a little more bearable..
http://www.instructables.com/id/Wireless-Headphones-3-minute-transmitter-cut-off-f/
I'm sure there is a way of doing it for a pc using a batch file or something but I'm not too up on my pc programming anymore..
Hope it helps..
Rob.
