HP Color LaserJet 3500 Printer Logo
Posted on Dec 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I changed the trasfer kit on my HP Color LaserJet 3500 and now the print is very light. I used and OEM transfer kit and followed the instructions provided by HP. Help
Anonymous
Level 2:
Novelist:
  • Expert 125 Answers
  • Posted on Jan 10, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
125
Questions
0
Helped
90995
Points
262
Calibrating the printer
Calibration is a printer function that optimizes print quality. If you experience any print quality
problems, calibrate the printer.
1. Press MENU to enter the MENUS.
2. Press to highlight CONFIGURE DEVICE.
3. Press to select CONFIGURE DEVICE.
4. Press to highlight PRINT QUALITY.
5. Press to select PRINT QUALITY.
6. Press to highlight CALIBRATE NOW.
7. Press to select CALIBRATE NOW.
Hope this works for you
pdouglasss
How do you reset an hp 3500 color laser jet printer?
follow the steps :
  1. Press MENU to enter the MENUS .
  2. Press c00047416.gif (Down arrow) to highlight CONFIGURE DEVICE .
  3. Press c00047417.gif (Select) to select CONFIGURE DEVICE .
  4. Press c00047416.gif (Down arrow) to highlight RESETS .
  5. Press c00047417.gif (Select) to select RESETS .
  6. Press c00047416.gif (Down arrow) to highlight RESET SUPPLIES .
  7. Press c00047417.gif (Select) to select RESET SUPPLIES .
  8. Press c00047416.gif (Down arrow) to highlight NEW TRANSFER KIT .
  9. Press c00047417.gif (Select) to select NEW TRANSFER KIT .
  10. Press c00047416.gif (Down arrow) to highlight YES .
  11. Press c00047417.gif (Select) to select YES . The transfer unit count is reset and the printer is ready to use.
Mohamed Hejazi
Afaqnama-LIbya
[email protected]
Very Light Printer on HP Color LaserJet 3500
Table 7-33. Causes for distortion or blurring
Cause Solution
Transfer unit is defective. Replace the transfer unit. Calibrate the printer
after replacing the transfer unit. See Calibrate
Now, later in this chapter.
Defective secondary transfer roller If it does not rotate smoothly or it is deformed,
replace the secondary transfer roller.
DC controller PCB is defective. Replace the DC controller PCB. Calibrate the
printer after replacing the DC controller. See
Calibrate Now, later in this chapter.
Calibrate Now
Use the following procedure to calibrate the printer whenever you replace the DC controller,
the formatter, the color misregistration sensor (PS12), the transfer unit, or the laser/scanner.
1. Press to enter the MENUS.
2. Press to highlight configure device.
3. Press to select configure device.
4. Press to highlight PRINT quality.
5. Press to select PRINT quality.
8. Wait for the printer to calibrate.
hope this helps
pdouglasss
2answers
HP 4500 Printer blank pages
Hi over the years on working on these printers I have found the transfer belt-kit causes this model to print blank pages i would try this
hope this helps
James
Transfer kit-HP 3500 laserjet
Hi dbourienne:
Yes it is but you may start having print quality problems ,but as long as the part has been ordered and will be installed soon, it will be ok to print.
pdouglasss
1helpful
Hp laserjet 3500 transfer kit
Hit the check botton on the control panel for the printer. Scroll down to "Configure Device" and hit the check button. Scroll down to "Resets" and hit the check button. Scroll to "Reset Supplies" and hit the check button. Scroll to "New Transfer Kit" and hit the check button. Scroll to "yes" and hit the check button.
Hit the return button (next to check button) until back at ready again. Transfer belt count should be reset now.
To make sure, from the info menu, scroll down to "print suply stus page" and hit the check button. Transfer belt should read as 100% now.
DON'T WORRY IF IT TAKES MORE THAN ONCE FOR IT TO TAKE. WE'VE SEEN IT TAKE 2 OR 3 TIMES OF REPEATING THE PROCESS (for no good reason) BEFORE THE MACHINE RESETS THE COUNT.
Hp 3500 faint printing and colours wrong
Rich,
Well, first off, are you using OEM or compatible cartridges? Compatibles are OK, just as long as they weren't rebuilt just by refilling. Secondly, you may want to check in the "Print Quailty" menu; here you will find info on increasing and decreasing the print density. Do you observe light printing over the entire page or just ceratin areas? How about certain colors? More to follow...............
Hp inkjet 3500 prints red as yellow
how do i get the printer to read that i have put in a new transfer kit.
2answers
Installing hp 3550 printer driver on new OSX leopard system
When I try to print from an access data base to the laserjet color 3500 usb printer.
Tried diff. drivers, diff usb cable, it works for a while but after several test runs the error reapears.
PCL XL error
Subsystem: KERNEL
Error: ColorSpaceMismatch
Operator: VendorUnique
Position: 9
2answers
HP COLOR LASERJET 3500
Hi!
If you could possibly manage to access the machine status menu and have it print to check the drum's life, fuser life, developer, etc.. pls refer. Kindly replace the toner cartridge accordingly use the menu settings when replacing any color if needed. Please print solid image or block in each color Cyan, Magenta, Yellow and Balck. Well see if what color causing the problem. Please let me know the print result it may be; washed out or too light, too bright or black, double image, or not clean. Don't hesistate to contact me again about the result.
Best regards,
Rosener Guyano
k24674
Grand Canyon Tech
Grand Canyon Tech
