E528-2012 LAPTOP
SOURCE: restore settings
hi the above is not true ..i have restored many acer laptops ..its very easy to do ...start the computer up you will get the acer logo first then a black screen with a cursor in the top left corner (this only stays on for a few seconds .) when this screen (black screen with cursor) comes up immediatly press alt and f10 this will then bring up a screen that says windows system restore ..just follow the on screen instuctions the first one will be 4 options as to what you like to do ...you need to do complete factory restore (think its the first option) and thats it just follow what it does and asks you to do ..be aware that you will loose everything you put on the laptop ..that wasnt already there when you purchased it ..every computer has a original copy of the factory settings and windows hidden on the hard drive ..your computer will be restored to the brand new condition it was in when you bought it ..dont worry if it seems to take a while and doesnt look like its doin anythin.it is and can take anything from half an hour to an hour for it to do it all...the computer companys and fixers dont like you to know this but trust me ive done loads of acers this way ..and sonys and gateways ..the trick is is to no what buttons to press on start up to access the windows restore facility ..an acer is alt and f10 ...hope that helps.
SOURCE: restoring averatec 3150 laptop to factory setings
With no disk you cannot restore your computer to a factory settings, at least that your computer has a second disk with the restore settings installed on it (usually this disk is called restored)
SOURCE: how do i restore a toshiba L350 laptop to factory
Hello, Bob.
Use the Recovery CDs that came with the system. If you no longer have them, order them through Toshiba. Here's their website:
http://www.toshiba.com/tai/
Hope this helps.
SOURCE: factory setting restore
Does the laptop have a restore function built in?
When you start it up do you see anything that indicates a restore program?
SOURCE: restore factory settings to acer aspire laptop
Restore and recovery
The restore and recovery features allow you to restore or recover the system
from a factory default image, from a user created image, or from previously
created CD and DVD backups. You can also reinstall applications and drivers for
your Acer system.
1 Press <Alt> + <F10> or select Acer eRecovery Management from the
Empowering Technology toolbar to start Acer eRecovery Management.
2 Switch to the restore and recovery page by selecting the Restore button.
3 Select the backup point you would like to restore from. You can also
choose to recover the system from a factory default image, recover from a
previously created CD/DVD or reinstall applications and drivers.
4 Follow the instructions on screen to complete the process
