Question about Hoover AAA140 Front Load Washer
Hoover hdb244 washer will not drain or spin - Hoover AAA140 Front Load Washer
2 Suggested Answers
6ya staff
SOURCE:
Dov Dror
  • 641 Answers
SOURCE: Washer won't fast spin or drain
The drain line is probably clogged. Maybe that a small sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump. To remove it from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub and try to remove the clothing through the port. Good luck
Posted on Sep 04, 2007
My hoover optima washer drains but won't spin. Help
I would suspect the timer contacts are burnt .
Mar 04, 2015 | Hoover Washing Machines
I have a Hoover Top Loader HNT2135. The problem is that it will not spin. Makes a noise as though it is going to spin but doesn't manage to.
Hi.
If it does make noise and does not spin it is usually the drain pump clogged. Disconnect power, reach the drain pump and check for blockage in there . If that is not the problem check in order drain hose at the back, lid switch, pressure switch, and finally pump and motor from underneath the washer. The switches and motors can be tested using a multimeter.
Here a page about drain/spin problem.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 13, 2011 | Hoover Nextra HNT 2135 Top Load Washer
The washer wont spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 27, 2011 | Hoover H130E Front Load Washer
Not rinsing or draining or spinning
heatman101
Oct 10, 2010 | Hoover HC6 110M Front Load Washer
My hoover washing machine wont spin and is full of water. model number is hnl 9146-z
It's a safety feature that doesn't allow the machine to spin when there's still water in the tub. The drain pump has probably failed and you would need to replace it (there are some good places online where you can buy appliances spare parts). Try to set your machine on a 'Drain' cycle and see if the pump works.
Nov 02, 2009 | Hoover Nextra HNL 3166 Z Front Load Washer
Hoover washer dryer saver 1300
I have inherited a hoover saver 1300 in new flat, the dials have worn away and it goes onto drying mode after wash, how can i have it on wash and spin only - NO DRYING? Thanks
Apr 12, 2008 | Hoover H120M Front Load Washer / Dryer
Hoover AAA140 Front Load Washer Logo
99 people viewed this question
Top Hoover Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
