Code 3527 - printhead carriage jam. I have managed to open the casing, remove cartridges, remove cartridge holder and depress a square ink pad which then allows the carrier to move, but once I reassemble and press ok it goes back into its left locked position. Any ideas? Kodak says they can repair but I cannot afford this.
SOURCE: Kodak i40 Scanner - paper jamming
First clean with a damp cloth, then try Isopropyl Alcohol. Dont use solvents. Check if papers are sticky. Stapled papers are 'sticky' even after removing staples. loosen them if required. Notmally rollers last 200,000 to 250,000 scans
S. Mohan, Chennai, India
SOURCE: red and green lines through prints from a kodak
clean the scanner with anti static wipes and vacuum clean the scanner, if this does not work then call the kodak techs again and they can send a cleaning kit or a replacement scanner. the lines are caused by dust in the scanner
SOURCE: Kodak ESP 3250. Error 3527. I put new ink
Contact Kodak. I think it's the batch of printers that were made around this time. I just contacted them (mine is the same age and I'm getting the same error), and they are sending me a new printer.
SOURCE: I have an E 6
The error is the ultrasonic sensor thinking it is blocked , there are 2 sensors one on each half of the transport small round grills approx 8 mm in diameter in the center just after the feed rollers if cleaning these doesnt help they are probably faulty and will need to be replaced , cleaning with compressed air can damage the sensors as they are quite fragile lightly blowing or carefully vacuuming is the best way
