Ovens Logo
Posted on Dec 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bosch convection double oven,ovens won't heat,only broilers work
Have a bosch electric convection double oven,  top oven stopped heating one year ago and bottom stopped yesterday. Broilers work on both. Fans still run as well.
Barry Coates
Level 3:
  • Bosch Master 3,463 Answers
  • Posted on Dec 17, 2008
Barry Coates
Bosch Master
Level 3:
Answers
3463
Questions
Helped
1406946
Points
12766
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
My top oven won't reach temperature. Convection and broil work, bake doesn't. Over a year ago I did a self clean...hasn't worked since. I really need it to work especially with Thanksgiving next week.
It does sound like the element may be bad. The control will cycle the bake and broil elements to even the heat in the oven. if the element is out the oven won't heat well.
Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
Bosch double electric convection oven: top oven will heat and display code E1 15 once it gets to 350 degrees, will continue to heat with no response to temperature choosen. Set oven to 350 degrees and...
replace the oven temp sensor, it looks like a metal rod sticking out from the inside back wall inside the oven. part here....
http://www.repairclinic.com/PartDetail/Oven-Sensor/650101/1557889
My oven doesn't heat up
It could be the switch or heating element
1helpful
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 • Dacor Ovens
700 series Bosch double convection ovens - Convection roast works, convection bake does not. Fast pre-heat does not work. We tried to reset ovens according to Bosch instruction manual guidelines, but it...
The good sign is that the motor works fine as do heaters. If the operator interface acknowledges feature selection by beeping or what have you, we can safely say the problem lies with the control board or relay.
General Electric Double oven wall unit
id say something different like a thermal fuze or relay
1helpful
No heat
relay in the control circuit maybe bad
Gaggenau oven won't heat on convection setting
this could be due to more than one cause selector switch faulty elements faulty. however this would mean both elements gone - there is one at the top and one at the bottom also worth while looking at the wiring to the convection elements. does the thermostat neon come on when convection is selected?
Top Bosch Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
