Ipad2
As this printer has no WiFi function it cannot print directly to an iPad.
however if you have an airport-express router you can connect the printer there with a USB-cable and use it wirelessly...
Canon Support Drivers PIXMA MP250 AirPort Express 802 11n 2nd Generation Guide to ports and connectors
SOURCE: How do I download my
Add any photos you want synced to your iTunes. Then connect your iPad and click on the iPad management tab when it opens in iTunes. There, go to the Photos tab and check the box to sync your photos.
SOURCE: Cannot connect my router to get wireless for my
Hey,
I believe there should be a tiny reset button in the back, which you'll have to press for 15 seconds using a paper clip. This will reset the ENTIRE configuration of the network, so it will reset with the DEFAULT username and password, which you might have to call D-Link if you don't have the information.
There's more information on that over here: http://www22.verizon.com/residentialhelp/fiosinternet/networking/troubleshooting/questionsone/86195.htm
Just a note: it might not necessarily be the router's fault because I've heard that many people had problems with their iPad's wireless network after they updated to the newest firmware, which is 4.3.3. So, if you don't want to do mess around with your router, you can either wait for a new software update, or downgrade it, if you have the necessary files.
Good luck,
-virjog
SOURCE: need a users manual for the ipad2
here is the link for the manual! and its a PDF file. You need adobe acrobat reader to use this!!
http://manuals.info.apple.com/en_US/ipad_2_user_guide.pdf
SOURCE: can not watch videos from youtube on my ipad2
That's because YouTube uses a software called 'Adobe Flash' for displaying Videos. iPad and all other iOS devices don't support Adobe Flash. So you won't be able to watch YouTube videos on iPad.
However, YouTube has launched a test version of their site in HTML5. Head over to youtube.com/html5Then "join the HTML5 trial". You should now be able to watch videos.
iOS devices such as the iPad and iPhone do not support Java or Flash. I believe you can get flash working if your device is jailbroken, but by default there is not much you can do.
