SOURCE: Quinny Buzz Frame Problem
Try contacting them directly!
This may be a manufacturing problem that they are not aware of !
Click on the link below.Copy and Paste your problem into the email if you like.
http://www.quinny.com/quinny/forms/contact.aspx?mode=contact&language=nl-nl
Hope this is helpful.
Good Luck!
SOURCE: Folding - Quinny buzz 3
HI, if it's the same model as I have: start with the frame facing you with the break on, you will see 2 long grey 'buttons' situated where the seat clips in to the frame. One of these buttons has arrows on it like this ^, this one you push in the direction of the arrows. The other you, simultaneously push in. You then push the whole frame down - this takes a bit of pressure. The whole thing should fold flat, you then secure it with the cable located near the wheel.
This sounds very complicated, it isn't once you've done it the first time - I hope it makes sense to you!
SOURCE: Buzz rear wheels wont inflate anymore
I just ordered new tyres and inner tubes from my local pram shop. 8.50 for tyres each and 5.50 for inner tubes. Pram centre in Glasgow. Also ordered a new front wheel for 29.
SOURCE: front wheels on quinny buzz are a nighmare....
http://www.babycare.nl/quinny-buzz-all-terrain-front-wheel-p-1819.html?language=en&name=Quinny%20Buzz%20All%20Terrain%20Front%20Wheel
