Question about HP PL5060N 50 in. Plasma HDTV
No picture, screen blinking, sound ok - HP PL5060N 50 in. Plasma HDTV
  • 1,267 Answers
I would say it is power supply related. Consult a Technician.
Posted on Aug 11, 2012
6ya staff
SOURCE:
Picture blinks on an off an has no sound how can this be fixed
TV pic blinks on/off when connected to satellite via hdmi - Forums ...
www.cnet.com > Forums > Sony
CNETApr 7, 2013 - We have a sony bravia LCD tv, model KDL-60EX500. ... The tv then started "blinking" on and off - no sound, black screen - for a half second or ... Samsung Series 3 (330), won't show any picture/no sound?
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
LG TV : Picture not coming on screen, but TV is on.
Jul 14, 2014
How many have 'blinking' issue with Samsung led tv
Jan 26, 2011
More results from www.cnet.com
VIZIO flickering Tv screen easy fix( no money ) - YouTube
? 1:58
https://www.youtube.com/watch?v=oWSFwS3FH_c
Aug 28, 2012 - Uploaded by Bill GatesBestfriend
VIZIO flickering Tv screen easy fix( no money ) .... I left town unplugged the Tv. When I came home home ...
Jan 26, 2016 | Televison & Video
Model 32ld452c. Why is there a black screen and no sound?
Sounds like main digital board fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Sep 06, 2015 | LG Televison & Video
I HAVE A SONY-KV-ES34M61TV,PICTURE GOOD,SOUND GOOD BUT LIGHT BLINKIG FIVE TIMESWHEN NOT PICTURE ON TV SCREEN FLESHING LIGHT IS STOP, PICTURE GOOD,SOUND GOOD BUT IN SELF DIAGNOSTIC SCREEN DISPLAY 005:255,IT...
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Feb 11, 2015 | Sony Televison & Video
42 inch philips lcd no picture no sound
Sometime a no picture, no sound still has the power light or some other led blinking. The blinks might be an error code that will isolate the problem.
In general on LCD TVs with no picture, no sound, no blink code, the main power supply has failed. The capacitors weaken and when bad enough, damage the power supply.
If there is a blink code, the most, if not all of the power supply is OK and the blink code could point to the problem.
Jan 19, 2011 | Philips 42PFL7422D 42 in. LCD TV
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
No picture on screen but power light blinks
May be the problem with your Pc. If you can hear a beep sound when booting the Pc is Ok. Otherwise check memmory for loose connection.
May 03, 2009 | Computers & Internet
No picture or sound, just blinking power light
Hi...I am sorry to say that I had this exact problem. It ended up being the upper and lower panel drives. I contacted Hitachi and even though my unit was out of warranty, they agree to pay for parts. I paid for labor myself, and it cost me $199.95.
Good luck with it...let me know how it turns out for you.
Aug 10, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Power light blinks and no picture
No picture - screen is empty. Sound is ok
Check IC101 (BA7630F), if video signal comes to input (pin 1) but not present at output (pin 14) then replace this IC
No picture and sound, only a high pitch sound at switch on
Remove horizontal transistor and measure the resistance across any two pins. This value should be no less than 200ohms
Picture fades away few seconds after start-up till no picture. Sometimes no picture at all. Sometimes picture OK for longer. Sound unaffected.
Faulty joints on CRT pcb. Cracked solder joints at tube socket connections on CRT circuit board. Caused variable supply to CRT heaters. Resolder all socket pins to pcb.
Nov 24, 2007 | Toshiba CZ36V51 36" TV
HP PL5060N 50 in. Plasma HDTV Logo
89 people viewed this question
Top HP Televison & Video Experts
Ekse
Thomas F. Schneider
Edward Easley
Edward Easley
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
