Erecovery management for acer aspire one zg5 keeps telling me it failed formatting and something about a "hidden partition". This began by trying to turn on the computer and goes straight to erecovery. I tried the alt+f10. still same thing and will not turn off unless i manually turn off.
Ask acer for this problem, when you buy a laptop you need to make recovery discs, you prolly did not do that. So now it asks for recovery files on the dvd disc.
If it has no dvd drive you should have made them on a usb drive.
If acer cant help you with that, reinstall windows thats the only option.
Partitions hidden can be removed but then there is no way to restore the pc to factorydefaults anymore.
When you decide to reinstall windows, you will see 3 partitions, remove them all, then make 1 partition click next and it will make a little partition for system files. the rest is used for windows, untill u partition the rest, like a d: e: drive.
SOURCE: d2d recovery
you can not use erecovery and d2d if your don't have the hidden d21 partition on your harddisk. and since you have replaced your harddisk you don't have it anymore.
mail to compurepair and see if he can fix it..
rate me if you want.
CS.
Hi there
You want to restore your computer to its original settings without
recovery CDs?
This recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook. Follow the steps below to rebuild your C: drive. (Your C: drive will be reformatted and all data will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1 To activate the BIOS utility, press <F2> during boot up.
2 Check to see if Acer disk-to-disk recovery is enabled or not.
3 Make sure the D2D Recovery setting in Main is Enabled.
4 Exit the BIOS utility and save changes. The system will reboot.
To start the recovery process:
1 Restart the system.
2 While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3 Refer to the onscreen instructions to perform system recovery.
Good luck and Merry Christams
SOURCE: i have 1recovery **** named aspire 5610 dvd2 should i have a dvd1 disk also
go to http://www.sysresccd.org/Download
download the iso and burn it to a cd.
boot your computer with it
read the explanations coming up on the screen and when you see that you can choose how to start, type "wizard"
choose the top choice (auto)
when it starts right click on the desktop and start GPARTED.
one of the discs will be marked as "boot"
right click the disc called "recovery" (or the one that is not marked as boot).
choose manage flags
set it to Boot.
press apply on top (not always needed tho)
in the left picture (the one that opened from the start)
type reboot
remove the cd when you see the acer logo again.
the acer recovery manger should start.
SOURCE: Hello i have an Acer Aspire One model zg5 netbook
You're going to need to boot it from the Windows XP installation disk, which means if you don't have a CD drive you'll need to get an external CD-ROM drive. This will fix the problem.
