Question about Brother MFC-9840CDW Laser Printer
Getting a black line on paper when printer warms up...
Everything with this All-in-one works fine, except for now I am getting a black line on the right side of the printed page, only when the printer warms up. I can print off about 10-15 pages initially with no problem, but if I print more I start to get a black line (not solid) on the page. As I print more, the "line" gets thicker. After waiting for a while, I can print a small amount again (10-15 pages) without the black line, but again, when warmed up same thing happens. I have contacted Brother about this, and have cleaned all the parts that they say to clean. The problem is not "part related", and I cannot figure this out, unless I just print only a few pages at once! ANYONE??? Thank you~
    Sergeant:
  • 331 Answers
Black lines on copy come from toner cartridge, or drum unit, or fuser unit which is in the back. check drum and see if you can see line, back of machine with flash light you may be able to see line on fuser roller. Be carefull Fuser is hot.
A copy that is good and then starts to get lines usually the drum unit...
Posted on Mar 28, 2017
4 Suggested Answers
6ya staff
SOURCE:
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: brother printer that prints a black line down center
probably a bad drum cleaning blade, It's part of the drum unit
Posted on Feb 03, 2009
Caleb Judd
  • 157 Answers
SOURCE: Brother printer prints solid black on one side
This is caused by a faulty drum/charging circuit or laser unit. The drum is positively charged with static electricity and a laser draws the image onto the drum (changing the charge to negative) the toner is positively charged to it will adhere to the negatively charged image which is now on the drum. your problem is that the drum is either not being positively charged or the laser is charging the whole drum. There is a corona wire on the drum, remove the drum, sweep the corona wire (there will be a tab that moves left and right) and try it again. next step is to replace the drum. if you dont have a spare drum or one from another printer then it may be more cost effective to buy another printer as drums are quite expensive and it may not even be the problem.
Posted on Jun 16, 2009
Alun Cox
  • 2679 Answers
SOURCE: Middle of print job - stops to CLEAN - then starts from pg1 AGAIN
This is a simple 3 step fix
a) Get rid of printer
b) Get rid of husband
c) Get new printer
Hope this works!! :-)
Posted on Jul 16, 2009
I can not align my cartridges on my HP F2420. When i print the test page , only the colored lines appear , nu black on the paper , and when i put that printer test page in the scaner it says ''Aligment...
The black cartridge needs to be replaced.
The printer requires the black as well as the color cartridge to be working
in order for it to align correctly
Feb 15, 2011 | Office Equipment & Supplies
Hp laserjet 4 plus - keep getting a horizontal black line
yes you have to catch printer making the line and then as a page is being printed you need to open door to stop paper after green cylinder(drum) as it is entering fuser, then you need to remove paper from printer without pulling through the fuser, if you see the line then rub your finger across line up and down page, if it smears at all then its the cartridge if not then the fuser
Apr 27, 2009 | HP LaserJet 4 plus Printer
Fine black streaky lines on every page
The Teflon is probably worn off of your fuser rollers.
Jan 21, 2009 | HP LaserJet 6L Printer
CX6600 prints black lines through out documents
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Now try to Print it should work fine.......... Still same Problem Catridges Defective......... Good Luck...........
Jan 19, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Black line when making copies
A line down a paper on either a printer or scanner is classic sign of scratched drum. The certainty of it is in the fact the line is at the same place each time. Drum needs to be replaced.
Don't forget to 4 star this solution.
Jan 15, 2009 | HP LaserJet 2840 Printer
Photo printing quality is poor
dont mix colored with photo. we had the same problem and i bought black and color and it worked fine after that
Jan 11, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Ip4300
Took a can of Blow Off (dust remover) and blew through paper track, and used a paper towel soaked in Isotope Alcohol and rubbed the tracking rails..
Everything seems to work fine for now except the canister paper holding is not feeding properly and the paper is getting jammed when you try to use it. This is not that important as long as paper can be fed the normal way and it doesn't jam..
Jul 12, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
HP 3310 - problem with black ink supply
I heard you can get the 3310 to do a pump up the tubes cycle but i don't know how to make it do it. Pressing the ok and cancel buttons when you power up didn't work for my machine. Which has too died a inkless black death!
Jan 31, 2008 | HP Photosmart 3310 Printer
Smudge marks on paper; otherwise normal
fuser is usually replaced as a assembly, it's the hot bit a back.
Can only be two things the drum or the fuser as our headstrong friend has correctly explained.
More than likely it is the drum they last about 4 toners i think.
Learn the art of getting a page to stop halfway threw printing, you want to stop the page after the drum has put a image on the paper but before paper has gone threw the fuser (hotbit).
Once you have mastered the position correctly by stopping the printing by opening the door and removing drum/toner cartridge, to reveal the paper that is printed but can be rubbed off, we will know if marks are coming from the drum (you will see them) or from the fuser, if print is fine
Jan 07, 2008 | Brother HL-2040 Laser Printer
Brother MFC-9840CDW Laser Printer Logo
61 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
