RCA HD52W59 HDTV Projection Television Logo
H Tanner Posted on Aug 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HD52w59 audio and convergence not working
No audio and the convergence is not working.
Anonymous
Level 3:
  • RCA Master 5,807 Answers
  • Posted on Aug 25, 2012
Anonymous
RCA Master
Level 3:
Answers
5807
Questions
0
Helped
271978
Points
13914
• Have a check on the fuse RCA FL231
(400ma, 125V) +40V Supply Power Supply/Deflection PCB
OEM RCA FUSE RCA259213 FL231 400MA 125V 3960400000 ...
other fuses:
http://www.fixya.com/support/t14107547-test_fuse
Rca tv modle #hd52w59 convergence problem need to know cong.location
if you need to know where the convergence settings are you click menu then setup and then convergence. I have the same tv as you and the picture looks like its 3d with red and green and the words on menu are doubled and I tried auto converge and it didnt work. If you figure it out let me know. it also might be a fuse.
Hi I have a rca hd52w59. the top half of the
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
1helpful
RCA HD52W59 HDTV Television--the picture 3-d images colots red blue and green, been working great till this after noon any help please
When you presss menu and then select settings is the auto convergence and convergence options still there or have they disappeared/ Let me know and I will assist you with the problem.
My convergence keep going out, I replaced the convergence twice. I have a rca hd52w59 modle
When you say replaced the convergence twice, are you refering to the convergence boards or the FL231 fuse? If its the FL231 fuse unless you replaced the DL231 and CL230 plus reflowed the solder on the flyback it will continue to keep blowing untill the 3 parts are replaced together and the flyback gets resoldered. If you replaced the convergence boards then try resoldering the flyback.
TV RCA HD52W59 NO VIDEO
Sound like convergence supply problem (small fuse near flyback will be open.
1helpful
RCA HD52W59 convergence problem
Point-by-point convergence can be set by a good technician, but the controls are not accessible to the customer. also check the fuse in the power deflection board.
Convergence
is this the same convergence problem in your previous post.. no convergence on a hd52w59? no convergence option in setup?...fl231 a small fuse next to flyback being blown causes this. The reason this blowns is poor solder connections on the flyback
2answers
Conversation
The service # is hd52w59 and then something like yx1 or etc..... On the model # tag, this is written in very small writing. There is no way to remove the convergence option. Go to menu the set up and there you should find convergence. Choose convergence and run auto converge. If this does not work then there is a failure on the convergence power supply, convergence amp, or the deflection/power bd.
HD52W59
Did you chane your ICs recently? If so did you replace the resistor near the ics? These resistors often fail and if you replace the convergence ICs without replacing them they will take out the new ICs quickly.
Rca hd52w59 projection tv.
New conversion ic's sorry. Nothing else will work.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
