TV and when i took it home and plug it up i heard a clicking noise that go on a on but no sound or picture shows,just a red indecator light cuts on and off,what could be the solution to this ploblems,thanks for you support
SOURCE: red light on power button flashes, but no picture....blank screen
I would suspect a problem in either the backlight assembly, or the power supply that drives it. If it's the power supply, the part may be over $100.
SOURCE: samsung 40" tv not coming on
I would check out the power supply module for bad caps with bulging tops. Check DC voltages at the output connectors, you should have 5, 12, 24V.
Testimonial: "This seems to be a common fault on these tv's. I probably wont attempt to fix myself even though the warranty has ran out. Thanx "
SOURCE: Hi, My SAMSUNG LE40R88BDX/XEU LCD 40
It sounds like the power supply board has some bad capacitors that need to be replaced. Samsung is covering the cost to repair this problem on some models. You can call 1-800-samsung to find out if your unit is covered.
SOURCE: samsung 40" standby button clicking on and off but...
common problem phone samsung for a free repair i did my tv was 3 years old .but it is a fault with some capasitors they will fix for free
