SOURCE: I have an GE universal control model #RC24914-E
Search online (google) they are available for download, usually free.
SOURCE: I have a sylvania tv
This remote uses a 4-digit code.Try one of the following codes: 0062 0004 0009 0135 0189 0183 1141 0227 0456 0008 0068 0075 0141 0161 . There is also a manual code search available.
With the TV on, press and hold Setup until the LED lights up, then release Setup. Press the TV button once (the LED will blink). Then press the On-Off button until the TV responds (up to 300 times). Then press Enter to store the code.
However universal remotes codes are limited to those for devices released at least 6 months before the remote was programmed. If your TV is newer, you may need a newer universal remote.
The manual is available here: http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/24914-Manual-Eng-Spa.pdf . The code lists are here: http://www.jascoproducts.com/support/universal-remote-codes.asp .
I hope this helps.
SOURCE: I have a GE universal remote RC24914-E and I can't
1. At the same time, hold down the "Setup" button and the button for
whatever electronic you're trying to program ie, TV, DVD, CBL/SAT,
etc...
2. Wait until the red indicator light comes on and stays
on. Release it, then enter in the code. The light should immediately go
off. If it blinks, then that means you've entered in the wrong code
3. This remote seems to have a 4-digit code which I was able to look up
here:
Go to the 4-digit code link and look for your brand.
BTW, I
have a Phillips Magnavox TV and my code is 0154 in case anyone needs it!
Hope that helps!
Read more: http://wiki.answers.com/Q/How_do_you_program_a_GE_RC24914-e_universal_remote#ixzz1CrD9vVn8
SOURCE: GE RC24914-E 1022
tengo un control general electric 24914-e y quiero el codigo para programar una tv marca toshiba
SOURCE: Tengo un control universal GE
necesito el codigo del control remoto ge rc24914-e para programar una tv toshiba
