You can validate
the HP60 ink cartridge's electrical health by running the 'Tap 41' diagnostics test (this procedure is specific to the F2480 model). Refer
to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate
and read the service test:
http://inkjet411.com/?page_id=440
1.
While holding the Power button, press
Cancel (X) button 4 times, then press the Color Copy button once.
2.
Release the Power button.
3.
The 'Tap 41' diagnostic test print
should print.
--- Providing the color cartridge is partially functioning
the Tap 41 diagnostic test print will be printed (this is a forced service
print test which is mainly used for the evaluation of ink cartridge electrical
health). A good HP 60/60XL color cartridge should display 1248 good nozzles,
while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If
the results yield anything different then the ink cartridge is likely damaged
and will need to be replaced. Refer to video on how to read the printout.
http://inkjet411.com/?page_id=434
---- If the
printer attempts to print the diagnostic test pattern (1 page) then the printer
is generally considered operational and functional, if nothing is printed, but
the printer attempts to print the pattern, then the tri-color ink cartridge is
either empty, clogged or severely electrically damaged (black ink cartridge is
not used). You can remove the tri-color cartridge, reactivate the tap 41 test
and the printer will print the diagnostic test print in black ink.
For information
on North American ink refill services at a major retailer near you (should you
wish to save ~50% on ink costs), general printing problem resolutions or advanced
HP printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error
bypass & printer reset methods, etc.), please visit Inkjet411:
http://www.inkjet411.com
