Question about Dell Latitude XT2 Tablet PC
I cannot access tablet mode
I'm using Win 7 32 bit. When I convert to tablet mode, the screen orientation should change automatically but it doesn't. Even when I press the screen rotate button to change the orientation manually, it doesn't change. When I press and hold the button, the screen just turns black. And will back to normal again when I press the button again.
How do I disable the auto rotate?
Windows, Android, iOS all below. Number 1 tip, MAKE and MODEL always on Fixya :>)
Press the Windows ( ) key + C, or swipe in from the right edge of the screen to open your Charms. Tap 'Settings' and tap 'Screen' in the bottom of the bar. Tap the little square icon above the brightness-slider to enable/disable auto-rotate.
Jul 22, 2015
How can I enable/disable the auto-rotate function in Windows?
https://us.answers.acer.com/.../how-can-i-enable%2Fdisable-the-auto-rotate-function-in-...
How to Enable and Disable Auto Rotate on Android - Technology Hint
https://www.technologyhint.com > Android
  1. Cached
Nov 12, 2017 - Android has the auto rotate screen option which automatically rotates your device's screen when you move your device between landscape and portrait mode. This feature is a useful one. But, not for all. If you don't want this option turned on, then you can disable this feature. In this post, we will see the ...
How to Lock Orientation to Stop Screen Rotation in iOS 10, iOS 9, iOS 8
osxdaily.com/2013/10/14/lock-orientation-ios-7-screen-rotation/
  1. Cached
  2. Similar
Oct 14, 2013 - Yes, you can still lock the screen orientation in iOS 10, iOS 9, iOS 8 and iOS 7 to prevent the display from rotating itself when an iPad, iPhone, or iPod touch has been physically turned onto its side. The orientation lock is now in a quicker access location contained within Control Center, making it much faster ...
Mar 29, 2018 | Tablets & eReaders
Tip
How to put and play iTunes protected videos on Samsung Galaxy Tab
The Samsung Galaxy Tab is a line of upper mid-range Android-based tablet computers produced by Samsung. Big screen with HD screen resolution that makes the display to be brighter. So Samsung Galaxy Tablets are good choice for movie buffs to watch videos.
As advanced mobile devices, Samsung Galaxy Tab can support almost popular video formats like WMV9, WMV7, WMV8, H.264, MPEG4, DivX, H.263, VP8, etc.
However, you may find your Galaxy Tab can't play iTunes videos in .m4v format, even with some popular iOS devices like iPhones, iPod, iPad, etc. Samsung Galaxy Tab still can't be played well.
Why Samsung Galaxy Tab cannot play iTunes videos
iTunes movies / TV shows / music videos purchased or rented from iTunes Store are protected by DRM protection to prevent users playing in non-Apple devices like Samsung Galaxy Tab.
So If you want to put iTunes videos and play them on Samsung Galaxy Tab, you need to remove DRM from iTunes media and convert them to Galaxy Tab friendly format like MPEG4.
In this case, a suitable iTunes to Samsung Galaxy Tab Converter is needed. M4V Converter Plus for Win is an ideal DRM removal tool and iTunes converter for Samsung Galaxy Tab.
Besides Galaxy Tab, it can also support a lot of presets for iPod, iPad, iPhone, Sony PSP, Sony PS3, Apple TV, Gphone, Walkman, Blackberry, iRiver, Creative Zen, Xbox 360 and so on.
With the clear and simple user-interface, you can use M4V Converter For Win to convert your DRM protected iTunes M4V videos to Samsung Galaxy Tab quickly with high conversion quality.
8ac7457ca487455ce3b6/tumblr_inline_njlks7XJve1s1ugu5.jpg">
Guide to put and play iTunes protected videos on Samsung Galaxy Tab
  1. Add your iTunes video files
Download, install and run the iTunes to Samsung Galaxy Tab Converter - M4V Converter Plus for Win, click "Add Movies" or "Add Files" to import your iTunes video files. Batch conversion is supported so that you can add multiple files for conversion at one time.
2. Select the output profile and customize settings for Sasmung Galaxy Tab
Click "Convert to" format list, choose "Android Device" option and find " Samsung Galaxy Tab ".
bda673445622e29c884d/tumblr_inline_njll9ziUfT1s1ugu5.jpg">
Tips: If you have some special need and can't find the right one, you can easily set bitrate, codec, sample rate, etc to adjust parameters that affect video quality and file size for the video you prefer.
9b7185b93e77f3a54990/tumblr_inline_njllohUVr21s1ugu5.jpg">
3. Start the iTunes video files to Samsung Galaxy Tab conversion progress
After everything is done, hit the big "Convert" button to begin encoding M4V files to Samsung Galaxy Tab.
View more info at http://www.m4vconverterplus.com/ Convert Any iTunes M4V to MOV
on Feb 11, 2015 | Samsung Galaxy Tab Tablet PC
Must change orientation on Paperwhite from landscape to portrait; how?
When reading a book, you can access useful features by tapping the top of the screen to display the toolbar and then tapping the Menu icon.
  • Landscape Mode: Change the orientation of the page from portrait to landscape mode.
  • Not all books / authors allow changing view.
Nov 11, 2014 | Amazon Kindle Paperwhite
Screen wont rotate ... How do I unlock
Double click home button
then scroll with your finger to the right look for first icon with a 3/4 circle with arrow tip that icon allows you to lock/unlock portrait mode
Mar 29, 2011 | Apple iPad (16 GB) WiFi Tablet PC
When i switch to tablet mode i have no keyboard to use
There's an on screen keyboard available! XP: http://www.microsoft.com/windowsxp/using/accessibility/oskturnonuse.mspx Vista: http://www.microsoft.com/enable/training/windowsvista/osk.aspx The Windows 7 Flavor is available through the Ease of Access Panel just like Vista. This might help out a bit.
Feb 14, 2011 | HP EliteBook 2730p Tablet PC
Hi. I have a problem with my fujitsu lifebook t4215. When windows is runnning and I change the notebook to tablet config, I cannot get the display/screen automatically rotated. Even when I press the Screen...
Do you have Windows 10? As there may be an issue with screen rotation.
However to check your settings:
  1. Place the tablet into Pad/Tablet mode.
  2. Click the Start menu and select Settings.
  3. Click System.
  4. Click Display.
  5. Scroll down and check the status of Lock rotation of this display .
Jan 05, 2018 | Fujitsu LifeBook T4215 Tablet PC
Disable TC4400 auto rotate
First in Control Panel -> Tablet and Pen Settings, select Display Tab, then click on Change button next to Sequence. I set 1 as Landscape - Primary, then 2-4 as None.
Second, Go to Control Panel -> HP Quick Launch Buttons -> select Preferences tab -> uncheck the checkbox that says, "Enable Automatic Mode Change"
This worked for me!
Mar 08, 2010 | Compaq tc4400 Tablet PC
Screen rotate
Hello snapshots,
Here is what you do:
1) Click on a blank area of the desktop (not sure why, but sometimes this is necessary). 2) Press the toolbox button on your monitor. It is located in between the rotate screen button and the secondary "Esc" button. A tablet shortcut menu should appear in the middle of your screen. 3) Select "Settings" at the bottom left of the menu. This will open a "Customize Tablet Shortcut Menu Settings" Window. 4) In the "Auto Screen Rotation" portion of the window, make sure the "Enable ActiveRotate" box is checked.  5) If you choose, you may also want to click the "Calibrate" button. This will step you through customizing the ActiveRotate to your personal preference. 6) Click "Apply" and then "Ok".
Please note, that with the internal wi-fi connection enabled, you cannot use the X61 in tablet mode in certain orientations. Nothing bad will happen if you attempt to do this; but you will notice a message popup telling you this, as well as having the screen automatically switch orientations on you. This is normal and has something to do with the wi-fi antenna location.
Hope that helps!
Jeff
Feb 26, 2009 | Lenovo ThinkPad X61 Tablet PC
Dell Latitude XT2  Tablet PC Logo
121 people viewed this question
Top Dell Tablets & eReaders Experts
Harvey Mahal
Steve Luck
Steve Luck
Rhonda Webster
Rhonda Webster
Are you a Dell Tablet and eReader Expert? Answer questions, earn points and help others
