Ge dbvh512efoww front load dryer power comes on and lights up you can hear it click but nothing happens when you push start, shows it's working on the panel, no motor hum or any sign of movement at all ???
SOURCE: My 1987 GE Dryer, Model # DDE5300GALWH,will not run all the time.
sounds like you need a new timer you can actually take the timer apart to check for a burnt connection
SOURCE: ge front load dryer wont start but all the lights
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going
bad...
Here are a couple of tips that I wrote will help you to figure out why your
dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
SOURCE: I have a GE profile
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
SOURCE: ge dbvh512efoww front load dryer
if you can move the drum freely and the belt isn't broke the motor is humming and most likely needs to be replaced.you can try this to see if it will run,open the door,with one hand hold the door switch in and with the other hand spin the drum while someone else presses the start button.sometimes the motor will run and work for one time or a month but it will hum again but at least you'll know it is the motor.hope this helps you figure out your problem.i tried to look up your machine but it says wrong model number.
