I received the TD without the base pedistool and poloroid does not carry the parts anymore. Need to replace the stand.
SOURCE: Poloroid 32 in HD LCD with DVD player
check for shorted diodes in the power supply. the power supply is located in the modual.
SOURCE: screen black. polaroid tv 32". have sound TV/DVD Combo TDA-03211C
sounds like inverter board. What it sounds like is happing is your LCD is working ut the backligkt board that allows you to see is kicking off. (as you still have sound) Which could be the (most likely) inverter board, or the power supply board. You can take apart and check for voltage at your power supply. The power supply has a pigtail with large white wires and a connector. Power up with the center back cover off and check your voltage at the white connector on the power supply before and after the screen gos out. If there is no large voltage loss it is your inverter board.
You can used boards on e-bay or
www.rns-systems.com
SOURCE: I have a 32
Sounds like the DVD player is defective. Just food for thought.. Try not invest in any make with a built in DVD player, they just don't last.
SOURCE: poloroid hd lcd tv manufactured in june 2007
The problem can be as simple as the LCD driver cable came loose or bad LCD panel driver board.
Please post back what you find. Your backlight inverter board is still working.
SOURCE: When I put a DVD in, it stays on loading for a few
With the dvd loaders in these particular units the laser tends to fault in them relatively fast. Replace the laser loader assembly, which is the entire assembly containing the laser, the mechanism where the disc slides in and out as well as the small motor that spins the disc. Good Luck.
