Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Why are only drawers in fridge cold & not making ice?
A few days ago, our Frigidaire PureSource model # FRS6LR5EM2 wouldn't dispense water & there was ice/frost on the back wall of the freezer. The water line behind the crisper was frozen, so I thawed it with a hair dryer. The water dispenser has worked ever since. I unplugged the refrigerator to let the freezer defrost, set the dials to factory setting for 24 hours, then set freezer to 4, and fridge to 5. Everything seemed to work ok, but after 3 days, it is not making ice, only the drawers in the fridge are cold, top is warm, and there is ice/frost on freezer wall again. Also, the lower portion of the freezer seems to be partially working, but the top shelf does not freeze. However, the water dispenser works fine & the water is cold. Any help you can offer would be appreciated. Thank you!
  • Official Brand Answer
  • 4,342 Answers
Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
Posted on Aug 14, 2012
6ya staff
SOURCE:
peyton32034
peyton thompson
  • 410 Answers
SOURCE: Fridge area freezing food; water dispensor line freezing
sometimes when the cooler weather comes in you may need to chnge temp setings to a warmer setting to prevent some items from freezing ie: leafy vegetables, water bottles, eggs, etc etc.
now if you are having total freeze up of everything in the ref section then you could have bad temp control or damper assy.
Posted on Dec 16, 2007
catriver
Ron Marek
  • 878 Answers
SOURCE: refrigerator side freezing
kjn, I think what happened here is that the automatic damper assy. is stuck in the open position. This is why everything froze in the refer area. This includes the water filter and cartridge. I would unscrew the filter cover and see if it's frozen in there. If you find the filter frozen, take a hair dryer and go over it lightly until it will unscrew. After that you will have to check to see if the damper is stuck. You should be able to hear it open and close by turning the control on and off. Or get a mirror and hold it at an angle in back to see the gates. Part number for the damper motor is 240440701. Not that hard of a job...Catriver.
Posted on Jun 16, 2007
robert samples
  • 1314 Answers
SOURCE: Frigadaire freezer cold but fridge compartment is warm
i need the complete model number to narrow it down they still make the frs20zrg to this day the last two numbers like frs20zrgwo or frs20zrgw9 is what will tell me what kind of defrost system it has the serial plate is in the fridge side up by the light bulb or on the left hand side or right hand side of the fridge compartment up near the top sorry to be a bother but its necessary
Posted on Mar 30, 2008
Anonymous
SOURCE: PLHS267ZA
The guide that funnels the water into the ice maker needs to be replaced. The cause of your problem is that water is leaking into the back, freezing there, and blocking the air flow. Mine sounded like an idling semi truck with engine problems.
Posted on Mar 31, 2009
dmftrucker
daniel hendrickson
  • 1922 Answers
SOURCE: Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Posted on Aug 23, 2009
Why is aSide by side fridge leaking brown liquid from below ice maker?
Thank you for your post, friend!
I understand that you are seeing a brown liquid come from under your dispenser area. I would recommend you having a professional come out to your appliance to check and assure the water lines are connected properly and not developing any moisture problems to form from under your dispenser. I hope this is helpful. -Matt
Sep 03, 2014 | Frigidaire Refrigerators
Amana side by side not cooling
What is the complete model number of your unit?
Dec 04, 2012 | Amana Refrigerators
I have a Frigidaire frs28zrg with puresource water filter purchased used so probably 3 to 6 yrs old maybe more. The dispenser stopped dispensing water rather suddenly, but it's still making ice. We...
Check the reservoir behind the crispers for frozen lines. If it is froze it will take several days to thaw out with the frig below 40 degF. If it is not frozen you can disconnect the line at the water valve and see if the lever is operating the valve. Switch, water valve and waterlines and filter. process of elimination to find the culprit. Eric
Jul 08, 2009 | Refrigerators
Ice Maker not making ice in new fridge
make sure the metal bar is in the down position
Apr 16, 2009 | Refrigerators
No water at door (or ice!)
first off manke sure t hat yo keep the paddle depress fpr a few mins, it will need to fill a resevoir inside the regfrig sect, may take am in beofre the water flows freely
Mar 08, 2009 | Frigidaire Refrigerators
Changing the water filter in my Frigidaire
My Frigidaire PureSource water filter housing wouldn't unscrew either. Even with the supplied plastic "wrench" and later a cloth-covered pipe wrench, it wouldn't budge. Since both my icemaker and my door dispenser stopped dispensing water, and the filter housing in the fridge wouldn't budge, I suspected that the filter was full of frozen water. (Sometimes things on the top shelf of the fridge freeze, so it was obviously too cold.) I used a hair dryer on the water filter housing for a few minutes, and then the water filter unscrewed easily. Sure enough, the whole inside was a block of frozen water.
This would have been such a simple repair, HOWEVER unfortunately it turned out that I wrenched it too hard and broke the inlet valve on the housing. As soon as I thawed out the filter and reassembled, water was pouring out of the top. Took off the big cover at the top ceiling of the fridge and saw my problem.
It's only about a $25 part, but I'd advise that you be careful to only turn, without rocking back and forth, the housing when trying to unscrew. I guess I wiggled it back and forth too much and cracked it.
Aug 02, 2008 | Kenmore 22.0 cu. ft. Side-By-Side...
10 yr old Frigidaire ice maker stopped making ice
check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
Oct 30, 2007 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
484 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
