Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
Posted on Dec 18, 2008
How to enable "Bravia Sync" on KDL-40V2500
I understand that Bravia Sync is a feature of the V series, including the KDL-40V2500. Supposedly it allows me to control my Sony AV receiver power & volume using my TV remote when the two are connected via HDMI. They are connected by HDMI and "Bravia Sync" is enabled on my AV receiver. But I can't find anywhere to enable Bravia Sync on the TV. Any hint on where to find that?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1534
Points
I also have the same problem and was wondering if you ever found out the answer to this problem Peter?
I have a Sony Bravia KDL 40V2500. When I turn it on it powers on but the screen is black. Any ideas why or solutions?
Back light inverters. Is got two one is the master and the other is the slave. If you check ther should be burning marks. They need to be replace eather one.
Thanks
1helpful
Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
1helpful
Have a new Sony Bravia KDL-40W500 keeps turning off into standby mode with 8 flashes.
There is some confusion on the model (KDL-40W500 vs. KDL-40V2500), so I will direct this toward the 40V2500.
On the KDL-40V2500, an 8X blink means the scan processer has gone bad, and the BU board needs to be replaced. If the problem is intermittent, the the AU board might be the problem, but if it all the time, bank on the BU.
A competent repair shop should be able to help you, or you can try calling Sony directly for assitance.
Hope this helps you...
Sony Bravia KDL-40v3000
NISK-TRY USING YOUR DIRECTTV MENU AND LOOK AT THE SCREEN FORMAT SETTINGS AND MAKE SURE YOU ARE AT 16X9 SETTING.JOETV
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
