Question about LG KG800 Cellular Phone
How to unlock kg800 without sim
Kg800 didnt recognize any sim card , what is the best thing to do?
Showing sos at signal indicator
Hi,looks like your phone doesnt recognize your sim card
1-your phone is locked by a sim card company and didnt recognize the other sim services(if so, use the same sim card that buy the phone in first day .for example you buy a locked phone from at&t so u just can use the at&t sim cards not others)
2-try another sim card to make sure your device is all right (unless if it is unlocked phone)
3-reset your phone to factory or hardware reset to check your software is working properly
4-may be you have problem with sim card protector IC that contains zener diode inside to protect your sim card from ESD( electro static discharge) if so go to certified repair shop to check and repair it for you
kind regards
Apr 17, 2013 | RIM BlackBerry Curve 8520 Smartphone
How do i unlock the sims card for an LG LG800G cell phone
To Unlock the Phone from the Network lock use the Unlock code,You can get the Unlock code from here Wickedunlock.com
and Unlock it step by step using the instructions below:
LG KG800 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your LG KG800 mobile phones. If you enter over a certain amount of wrong unlock codes on your LG KG800 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your LG KG800 with its ORIGINAL SIM Card.
2 - Then compose : 2945#*7101#.
3 - In the menu that appears go to "Settings".
4 - Then select "Security".
5 - To finish select "SIM Lock" and Enter the Unlock Code.
ORIGINAL: We mean, to use the sim card that was originally given to you by your network/service provider along with the LG KG800.
Aug 07, 2011 | LG KG800 Cellular Phone
Phone saying insert sim card have inserted sim with credit on but nothing happens
Try power cycling for the phone. Please follow the steps below:
1. Remove the battery from the phone while it's turned ON.
2. Remove the SIM card.
3. Leave the battery and the SIM card out for five (5) minutes.
4. Put the battery and the SIM back and turn the phone ON.
If same problem occurs, try using another SIM to isolate the problem. If same thing happen after trying another SIM, then the phone needs repair. You may need to contact the manufacturer.
Have a great day!
Nov 02, 2009 | LG KG800 Cellular Phone
Locked
you have to enter sim codes for your phone to work in different places
Nov 14, 2008 | LG KG800 Cellular Phone
Unlocking my lg Kg800
You can't get code free. You need to buy. Try here www.allgsmunlock.com
May 17, 2008 | LG KG800 Cellular Phone
What is the PuK for a LG Chocolate KG800? Please help me!
The PUC (Personal Unblocking Code) is a code for you SIM-card. Either you've got it with your SIM-card package, or if not you can get it by contacting your network provider.
Mar 29, 2008 | LG KG800 Cellular Phone
LG KG800
PHONE UNLOCK PROCEDURE
Please follow the instructions below to unlock your LG KG800 handset:
1. Insert a Vodafone Australia working SIM card.
2. Ensure the phone is charged and then switch the phone on.
3. Enter 2945#*7101# while in standby mode
4. Select Menu, then go to Settings > Security > SIM Lock > Network
5. Select Deactivate and enter the 8-digit NCK unlocking code provide for your handset..
6. The handset will be unlocked automatically and will display "Done".
Feb 24, 2008 | LG KG800 Cellular Phone
Cell phone trouble
I know this sounds dum but!!
does it say
insert sim
or
insert correct sim?
Nov 21, 2007 | LG KG800 Cellular Phone
LG KG800 PHONE
Try out another SIM card if you havent already if all sim cards dont work then you may need a new phone. unless your still under warenty. then give them a call. if its not all sim cards just give your provider a call and get a new sim. hope it helped
Aug 28, 2007 | LG KG800 Cellular Phone
LG KG800 Cellular Phone Logo
113 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
Rusum Gupta
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
