How con i INCREASE , color of copy in toshiba 452
please sent to my add the GUIDE code toshiba 452
[email protected]
0+8 start 400>start> 0> Enter> 0+9
Toshiba e studio 452 Can not start Application. m/c not run
Pls help me.
08 - 400 selec 0
TOSHIBA E-STUDIO 452 showing error code C440...
0+8 start 400>start> 0> Enter> 0+9 problem how to return
Thanks a lot bro
SOURCE: toshiba estudio 4511 error code C440
Press 0-8 then enter 400 and make it 0 then press print switch, if doesen't work u have to change thermostar, then if not working change heater, if not then IH board, and the last solution is to change the system board.
SOURCE: toshiba e-studio 232 says c440 code
This problem is caused by the thermister in the fuser section. To reset shut macine off, then turn it on while holding down the 0 and the 8 key down for more than ten seconds then release. This is service program mode, now press 4 then 0 then 0 and then the start key, you will see a nuber in the screen, press 0 then start key this should reset that code if not the thermisters need to be replaced
SOURCE: Hard Drive error No. F105
F105 is "other HDD error" . Start the copier holding 0 and 8, it goes in a test mode, then punch 690 and presss start key. Restart the copier. If does not work you might have to replace the HDD and reinstall the firmware. Let me know.
SOURCE: error code c440
Hello sir; C440in this machine,it means fuser unit problem, but it can be reset the procedure as follow;
1, hold down "0" and "8" keys while turn on the power.
2, enter 400 press start.
3, enter 0 press set or enter.
After rebooting the machine starts normally, But after warming up within few seconds the error shows again.....
Please help
