Question about Janome Memory Craft 4800QD
Janome, memory craft 4800, sewing machine
Everytime I try to push the foot off my sewing machine, the screen says 'error'. does anyone know how to resolve this problem.
  • Anonymous Mar 27, 2014
    Cleaned out all the lint but it still won't work.
  • Anonymous Mar 31, 2014
    janome sewing machines sencor craft 7100 how can i oprate this ?
How to delete programmed patterns and start new lettering
Posted on Jul 11, 2008
6ya staff
SOURCE:
Trying to thread bobbin and viewed manual several times. singer model 7258. screen first flashes C3 and then ][. cannot find troublr shooting codes in manual.
Why do I keep getting a C3 error (accompanied by lots of beeps) when I turn on my machine?The C3 error as well as the beeping when you turn on your machine indicates the foot control plug is not fully pushed into the sewing machine. Turn off your sewing machine and push the foot contol plug into the machine fully. Turn your sewing machine back on.
Oct 22, 2017 | Singer Sewing Machines
Error message foot too high. To correct this, it is necessary to restart the machine. Unless it is impossible to continue sewing.What is the problem?
Try taking your presser foot off and lower the presser foot lever. Does the error code go away? The machine won't sew without the presser foot to hold the fabric down, but without threading the needle, will the machine run without the presser foot? Now try the standard presser foot (usually J ) and if you get the error code then the sensor at the top of the presser foot assembly is out of adjustment. Without knowing more about your machine this is all I can suggest.
Good luck,
Bob
May 30, 2017 | Sewing Machines
Brother sewing machine foot pedal does not make machine sew.power is on,but pushing on pedal makes machine say error.opened foot pedal,but do not see obvious problem.wonder if way to troubleshoot?
The owner's manual probably has a troubleshooting section. If the machine is giving an error, search for that error:
Make Model (error code)
Feb 26, 2017 | Brother Sewing Machines
I have error C7 on singer one plus and it wont sew at all?
I was getting a C7 error on my Singer Heritage sewing machine every time I pushed the pressure foot. I decided to see if the reverse sewing button would work and it did. Then I pushed the pressure foot to sew again and it worked. Hope this helps someone else.
Jan 27, 2013 | Singer Sewing Machines
I am trying to make a buttonhole using the buttonhole foot and everytime i go to sew the machine beeps and will not let me sew?
if you have a automatic buttonhole , then you should have a buttonhole lever that you have to pull down, before you start to do the buttonhole,, my machine will not let me do a buttonhole unless I pull down the buttonhole lever
Nov 16, 2010 | Singer 7436 - INGENUITY
I am getting error message E4 when foot pedal is plugged in. Unplug the foot pedal and the machine goes back to normal with the exception that you really can't sew without the foot pedal.
Your reverse reinforcement stitch button was pushed or needle position was pushed while bobbin winder was moved to the right. You can download a free manual brother-usa.com and you will see all of the troubleshooting and error messages there
Sep 10, 2010 | Brother CE4000 Computerized Sewing Machine
Keeps giving me the Fc warning signal no matter what I do
The foot control has been disconnected while sewing. Turn off te power and connect the foot control.(connected to foot pedal on the floor has come loose from machine body)
Jul 15, 2010 | Kenmore 19110 Computerized Sewing Machine
Brother CS 6000
With the foot pedal disconnected from the machine, push the button with the - and upward arrow. to stop sewing use the same button. It is the first button closest to the needle.
Jul 29, 2008 | Brother CS-6000
Presser foot down, but still get error "E1"
I had the same problem. It started after I took the cover off to fix something else. After I screwed the cover back on, I kept getting the E1 message even when the foot was already down. I took the cover off again, and I found that there is a metal tab at the top left of the front cover, that is pushed by a metal tab in the back that moves when you put the presser foot up or down. You can see this metal tab moving in the back if you put the foot up and down with the cover off. Just putting the foot down(I think) before putting the cover back on fixed it so one metal tab is on the correct side of the other metal tab.
Jan 01, 2007 | Brother CS-100-T Computerized Sewing...
Sewing Machines Logo
636 people viewed this question
Top Janome Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Thomas F. Schneider
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
