I HAVE TWO S602 FINEPIX FUJI CAMERAS, AND A 2-GIG MICRO MEMORY CARD. SUDDENLY WHEN I PLAYBACK THE PHOTO'S I HAVE TAKEN, IT TAKES AGES TO LOAD EACH PIC, (APPROX 2 MINUTES FOR EACH ONE), THIS IS FOR BOTH CARDS IN BOTH CAMERAS, SO i DOUBT IF IT IS A CARD OR CAMERA ERROR, HAS ANYONE HAD ANY EXPERIENCE WITH THIS, THANKS,
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
SOURCE: memory card
Because this camera only understads FAT16 formatting, it does not accept any card larger than 2GB so your best bet is to use the current crop of standard 2GB CF cards, most newer ones (usually 16X and faster) are alsa fast enough for continuous VGA video as well. The best brands IMO are Lexar and Sandisk, but avoid the WA enabled cards, this camera can't make use of WA, it just slows the througput down.
Alternatively you may partition your 8GB card to a 2GB partition, but the rest of the card won't be accessible.
