Nokia 5030 no signal pls signal ways or diagram too solve my cell
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
- To get the your Nokia 5030 IMEI code of
your mobile phone. - With the help of this IMEI code we can get the master code of your mobile and unlock the mobile and reset it with a new password.
- The IMEI number can usually be found on the sticker underneath the battery or by typing *#06# into the phone keypad.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
SOURCE: hi, pls solve my problem my cousin in london he
Give unlocking.com a try to get that restriction code. When it say that that means the phone is locked to the original carrier.
SOURCE: sir i forgot my nokia
the common or default security code for nokia handhelds are 12345 or 123456 hope this helps
SOURCE: i want to format my cell nokia 5030
first you have to switch off your phone then press hold these keys atonce 1.press hold ( * ) star key 2.call dialing key (green key for making a call) 3.then press 3 4.at last switch on the phone if your phone is formatted correctly then on the next screen your phone ask you to set the time zone! vote me if this is helpful for you!
SOURCE: I lost my nokia 5030 mobile imei
I lost my nokia 5030 mobile imei no:I lost my nokia 5030 mobile imei no:I lost my nokia 5030 mobile imei no:356074034667340 pls find my mobile.. pls find my mobile.. pls find my mobile..
