Question about ZTE Warp
My zte won't send any text messages because of shortage of numbers
It keeps saying please resend using a 10 digit number but every time i would have to create a new message to get the area code and the rest of the number then it will let me send a message. how do i make it remember the entire number?
    New Friend:
I had the same problem with mine, i had to erase the person i was trying to msg, and then resave them under contacts and then put a 1 infront of the area code then the number, this seemed to work for mine, hope it helped
Posted on Nov 18, 2012
  • ZTE Master
  • 14,641 Answers
For sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Posted on Aug 14, 2012
2 Suggested Answers
6ya staff
SOURCE:
SOURCE: cant send picture message with my zte warp
could be that the file data is too high or that the receiving phone doesn't get phone messages, try sending a text photo to a old phone you have you to your email. If that works then its probably just the receiving parties issue.
Posted on Feb 17, 2012
My zte warp sequent text just keeps sending but never actually sends the text
for sending text messages :
4.note it down
Good luck
Oct 30, 2012 | ZTE Cell Phones
Can't send text message
4.note it down
Good luck
Aug 20, 2012 | ZTE Warp
How and where do i get music to download to my samsung gravity 3?
You will either need a USB cable( to move more than about 5 songs at a time) or you can just email the songs to your phone WITH OUGHT data charges. I usually use email to send ringtones/songs to my internet-less phone, because I don't want to buy a cord. You can buy a cord on amazon Here, though:http://www.amazon.com/Samsung-Gravity-T479-Data-Cable/dp/B003XIA4O8/ref=sr_1_3?ie=UTF8&qid=1306439716&sr=8-3
The way you would do this is by sending it to your text message inbox. Actually, when you buy your phone, the provider gives you an email adress to go along with it. So to send a message to your phone:
1.Open up your email
2.Where it says "To", type one of these numbers:
Alltel [10-digit phone number]@message.alltel.com
Example: 1234567890@message.alltel.com AT&T (formerly Cingular) [10-digit phone number]@txt.att.net
[10-digit phone number]@mms.att.net (MMS)
[10-digit phone number]@cingularme.com
Example: 1234567890@txt.att.net Boost Mobile [10-digit phone number]@myboostmobile.com
Example: 1234567890@myboostmobile.com Nextel (now Sprint Nextel) [10-digit telephone number]@messaging.nextel.com
Example: 1234567890@messaging.nextel.com Sprint PCS (now Sprint Nextel) [10-digit phone number]@messaging.sprintpcs.com
[10-digit phone number]@pm.sprint.com (MMS)
Example: 1234567890@messaging.sprintpcs.com T-Mobile [10-digit phone number]@tmomail.net
Example: 1234567890@tmomail.net US Cellular [10-digit phone number]email.uscc.net (SMS)
[10-digit phone number]@mms.uscc.net (MMS)
Example: 1234567890@email.uscc.net Verizon [10-digit phone number]@vtext.com
[10-digit phone number]@vzwpix.com (MMS)
Example: 1234567890@vtext.com
3.Attach files just as you would a picture.
4.send, and you should recieve as a text message.
Hope this helps:-)
May 26, 2011 | Samsung Cell Phones
My mobile will not send text messages. The texts remain in the outbox with a message saying "Resend at", followed by a time. When the message sending fails it displays a message saying "Memory full. Close...
4.note it down
Good luck
Oct 12, 2010 | Nokia E63 Cell Phone
I can receive txt msg and make and receive calls on my nokia e65 but cannot send txt msg. Why would this be?
hi....
I think when you send text message it says message failed...right..???
This is because there is option in your mobile called as message service centre number.please check weather this number is correct.Call your service provider and you can get this number.
And also there is an option called as reply via same message centre please put this to 'NO'. now you can send messages
To go to this options please check follow these steps....
1.open 'menu'
2.open 'messages'
3.Go to 'message settings'
4.in that open 'text message'
5.there is an option called as 'message centre',please entre your new message centre number and save it. set this as your message centre
6.Check the option 'reply via same centre' and please put it to 'NO'
Thanx
Jul 17, 2010 | Nokia e65 Cellular Phone
My Nokia e51 wont send txt msg's, it used to be
there is a service center number in your message setting. if it is edited your messages wont go . correct service center can be taken from your service provider. if that is right the reset your phone once it will start working fine.
Aug 27, 2009 | Nokia E51 Smartphone
Text Error 1121611611
In order to send a text message on the iPhone, you must have the entire 10-digit phone number in your phonebook. For example. If you are trying to send a text message to the phone number 555-1234, you must also enter the area code. If the area code it 412, you must put in 4125551234 for the phone number.
Hope this helps!!
Nov 14, 2008 | Apple iPhone Smartphone
N95 - Pain in the Ar**
Make sure you're using your mobile service provider's settings and msg center number, and that your setting for reply is set to: reply via same center number to; NO
Feb 28, 2008 | Nokia N95 Cellular Phone
Error 96 While text messaging, Help please?
I have the same problem. You have to use the area code, the full 10 digit number. Even the phone numbers stored in your memory need to include the area code for the text to send.
Mar 05, 2007 | Samsung SPH-a660/VI660
ZTE Warp Logo
595 people viewed this question
Top ZTE Cell Phones Experts
vince
john smith
Dakshinamurthy...
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
