Is there an alternate controller board for the Splendide 2000s? I need to get 2 or 3 more months out of it! Woudl the tricity Bensix penal work for a bit? ORRRR Can i rig it to Tumble manually, Spin Manually Pumop manually and Fill manually? then i can operate it in a primitive basic fashion till i dump it when i move!! I dont care about the drying bit... Thanks! N
To do what you are saying is to remove controler and by pass every thing with individual switches would work in a fashion but is not feasable best dump it now or repair propely for safety reasons remember a life is worth more than any money when playing with electric and water repair or get new dont take chances a family menber is is loved and would be missed
Thanks for the feedback.... I decided not to risk killing us all.... and dug further into the machine... taok ons of things out... and found the problem was a disconnected wire on the motor! Tested motor, worked fine, put everything back and VOILA!! It all works perfectly!!
Thanks for the feedback.... I decided not to risk killing us all.... and dug further into the machine... took tons of things out... and found the problem was a disconnected wire on the motor! Tested motor, worked fine, put everything back and VOILA!! It all works perfectly!!
SOURCE: Splendide 2100 no longer dries clothes
We had the same problem with our splendide 2100 top loader. If you remove the top cover, you will find 2 circular like black discs (the size of a dime) on the right hand side about 6 inches from the front. You need to push those down (with a very small blunt object) to reset them. Please make sure that you unplug your washer/dryer before you attempt this. Good luck.
SOURCE: splendide 2100 washer/dryer now fails to dry -
Remove the top - two screws in the back then slide forward
In the front right top you will see the air box and the terminals for the heater coil along with other wires and sensors. Start the washer on a dry cycle and check the voltage to the heater terminals. You will be looking for 120 AC. If voltage there but no heat the heating element is bad. If no voltage there follow the wires to the overheat switches and check the voltage on the other side of these switches (round devices with two terminals on top). If there is voltage there then the switch has tripped. Unplug the machine. Look for a spot of paint on this switch, scratch it away and you will see a small hole. Insert a strightened paper clip into this hole and push to reset the switch. Re-power and test the results.
No power to these switches probably means a bad circuit board $$$.
SOURCE: My motor yacht's Splendide Washer Dryer combo has
Thor Appliances - www.thorappliances.com - and LG both have machines that can replace the Splendide.
SOURCE: Splendide 2000S
www.splendide.com
1-800-356-0766 #5 (503-656-2280)
503-722-9202
[email protected]
Monday-Friday, 7:00am - 4:30pm (PST)
You may also want to try a RV retailer in your area, they may direct you to a used part.
