Televison & Video Logo
lary hedg Posted on Aug 14, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No sound for earphone, there are no rca jacks, the earphone is used to attach speakers, but there is no sound from the earphone jack
francoise cleofas
Level 3:
Genius:
  • Insignia Master 2,432 Answers
  • Posted on Aug 14, 2012
francoise cleofas
Insignia Master
Level 3:
Genius:
Answers
2432
Questions
0
Helped
298406
Points
6852
If their is a sound from the internal speaker then the problem is with in only in the earphone jack or in the connection. to access the internal part of the tv you need to remove the rear cover. locate the earphone jack terminal re soldered and check the connection at the board ( PCB). you can check also the continuity, attached powered pc speaker then use an analog tester and check weather their is a connection coming from the stereo input jack going to the terminal of the earphone jack of the tv. if no connection replace with new earphone jack. good luck hope this can helped.
4 Related Answers
Anonymous
  • 8909 Answers
  • Posted on Jan 08, 2011
SOURCE: where to hook up headphone jacks to allow TV
Unless you have an external headphone amplifier, you need to use the headphone jack socket, if there is one. Some newer TV's allow for separate headphone volume and speaker volume control.
Have a look in your user manual.
Anonymous
  • 113 Answers
  • Posted on Feb 08, 2008
SOURCE: Lost Owners Manual - Can't get Audio Out Jacks to Work
This tv does not have an amp to power those speaker. The audio jacks are to provide audio to a tuner and amp which then power separate speakers. The audio output jacks just cant power speakers on its own in this set. Hope this helps you.
Don't forget to rate answer
Thanks,
Josh
gopakumarg43
  • 76851 Answers
  • Posted on Nov 29, 2010
SOURCE: How do I switch inputs? I want to use the RCA
Hello
There is no other way to select the input without a remote control for your TV. You just buy one universal remote control and programme it to match your TV. There are so many models of remote controls are in electronic market. Just buy one. I hereby send the models that matches your TV and its codes alongwith.
RCA universal remote models RCR 412BN/ RCR 412SN/ RCR 412 SIN.
Codes are
20000, 20042, 20202, 20880
Direct Code Entry
Direct Code Entry lets you enter a code from the accompanying
code list for your brand of device. It's not as easy as the other
methods, but it's potentially the fastest method.
Manually turn on the device you
want to control
Find the Code List that came with
the remote. Locate the section for
the type of device you're trying to
program, and find your brand in
that section. Circle the codes for
your brand and keep them handy.
Press and hold the device key you want to program (the
ON•OFF key comes on).
While you're holding down the device key, use your other
hand enter the first five-digit code for your brand in the
code list (the ON•OFF key goes off after the first digit).
When you've finished entering the five-digit code, keep
holding down the device key and look at the ON•OFF key.
Is the ON•OFF key on?
YES: You're done! You've programmed this device key.
NO, it blinked four times and turned off: You have
either entered a code number that is not in the code lists or
missed a step in the code entry procedure. Try step 3 again.
NOTES
Remember to enter the code for future reference in the box
provided in the Code Retrieval section of this manual.
If your brand isn't listed in the code list, use one of the Code
Search methods to program the remote control. (Refer to the
Auto and Manual Code Search methods.)
If you release the device key any time during the Direct Code
Entry procedure, the ON•OFF key blinks four times, and
the process is exited. The last programmed code under the
device key is retained.
Test the remote with the device to make sure the device
key is programmed with the correct code for maximum
functionality. If some features don't work, try a different code
in the list.
NOTES
Throughout the programming of each key, be sure to keep
the remote pointed at the IR sensor of the device you are
currently programming the remote to control.
code. See the "Testing the Code for Maximum Functionality"
section below for more information.
During the Brand Code Search, the remote ignores
keypresses that aren't part of the search.
The search times out after two minutes (the ON•OFF key
blinks four times and turns off, and the last programmed
code under that device key is retained).
The ON•OFF key blinks four times and turns off when the
remote has gone through all the codes. The remote exits the
Brand Code Search. If your device hasn't turned off yet, tr
different search method
TIP: Each device key is associated with a type of device-the
TV is preset to search for TVs, SAT•CBL•DTC for satellite
receivers, cable boxes or digital TV converters, DVD for DVD
players, and VCR•AUX for VCRs and DVRs. To program a
device key for a different type of device, see the Changing a
Key's Device Type section.
The ON•OFF key serves as an indicator light during
programming, giving you feedback at each stage of the
process.
Ok
Anonymous
  • 43 Answers
  • Posted on Jan 23, 2008
SOURCE: Sony Trinitron Model KV 20M20
You may have a bad H board which is the board that has the voulme/channel buttons on it. You may want to have a Sony asc give you an estimate to repair. Good Luck
How to make sound loud enough to hear normal hearing
Carole... Is there a "Audio Out" on your TV or perhaps a 'earphone' jack?
MANY MANY amplified speakers and boom boxes may serve you very well! Of course you will need only ONE. You will also need the extension cable that interconnects the two devices.
A "adapter" may also be needed IF your Audio Output Jack is a RCA type?
RCA Plug to 3 5mm Jack Adapter
https://www.showmecables.com/3-5mm-mono-plug-to-rca-plug-cable-6-ft?gclid=Cj0KCQjwzIzWBRDnARIsAAkc8hGtGWhZt7MqTHAoDRzY5LJKsJYpWgLFlxLjGV1bWEuo908cplIcAr0aApLvEALw_wcB
Anthony
1helpful
Beautiful picture but no sound.What could it be?
No speakers attached? Sound on mute? Earphone jack stuck in earphone mode, with the male jack removed?
Problem with using headphones
If the main speakers in the laptop work then the problem lies in the earphone jack, but it is a good idea to hook a second one just to be sure, if no change! the laptop must be dismantled down to the motherboard level, chances are the earphone jack is bad.
I have a clarion vz400 in a 2004 doge truck with an infinity sound system. It plays sound well through the radio and bluetooth but when you try to play a dvd or iphone through usb there is no sound. What...
your unit are not compatible to each other. try other usb that can compatible to the unit Clarion. Option use audio jack like earphone jack and RCA jack if you don't want to replace your DVD and Iphone
No SOUND
If it has an earphone jack try to hook up your headset just to get hint if your problem is in the sound output ic. Listen carefully to your headset if there is a sound or none. If you hear a sound then you the trouble is in between the earphone jack or to your speaker. Just test the speaker and you will isolate the problem. How to test the speaker if good, simple got a battery (either AAA,AA,C,D size) then tap the speaker across the battery when you hear a crackling sound then it is good. If you confirm that the speaker is good then the faulty parts is your earphone jack, replacing it will cure the problem. If you don't hear a sound then through your earphone then the trouble is in the output I.C. or some parts around it and you need a technician to isolate the problem.
If you don't have an earphone jack then I've advice you to look for a qualified technician to look for a defective parts on the sound section.
Thanks for using fixya...
2helpful
2answers
My S Video from laptop works with TV however no sound on TV
No, S-Video is video only. Look for the Audio output jack on your computer (usually its a lime green earphone hole). you will need a 3.5mm to RCA Stereo output wire, and attach the RCA audio to the AUX input of your TV, and then hook it to the Earphone/Speaker output jack on your computer. Then you will have to set your computer volume at about 75% (not all the way up, but more than halfway up). Then you can adjust the volume on the tv set. (just fyi, if you have bass boosting on the COMPUTER, turn that off, as well as any Equalizer or BASS/TREBEL booster. Set your mixers and boosters to NORMAL for best sound. not doing so could produce popping or scratching in the sound from the TV, also, if you have your PC volume higher than 75% that can also cause popping)
Connect 2.1 Logitech to a TV
if you have an RCA output for your audio. you can buy a lead that goes from 3.5mm headphone jack into 2 RCA phono plugs.
EarPhones
several ways.....Wirless headphones that have a small transmitter that you attached to RCA jacks coming out of audio of VCR. You can walk around or sit as far away as you need.
2nd. CONVERTER:: A RCA male plug [ again you conect to back of VCR audio plug] to audio [female] jack [you connect earphones]
2answers
Connection to a portable tv
The RCA set on a tv [Red /White /Yellow] are INPUT[ VCR/DVD player] not out put. Hook the speakers up the the 3,5mm earphone jack though you will need a conveerter plug like this
Top Insignia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
