Recently bought this scanner as a gift. Tried installing the AdobePhotoshop elements4.0 but it kept cancelling itself saying that a more efficient program was already installed on the computer. Installed the Driver with no problems. Now the scanner won't do anything. When I go through the start menu to the scanner, I get a dialog box telling me that the computer can not communicate with the scanner. When I hit the scan button on the scanner nothing happens. When I click on the scanner icon from my computer, it will attempt to scan and then say it can't because of scanner hardwear error. The lamp light is on, but I have noticed that the scanner does not move out over the slide. In fact, it only moves a couple of millimeters. Any ideas? Whats up with this thing. It's going to learn to fly through the back yard any second now.
SOURCE: Pacific Image 1800u scanner and XP pro compatiability problems ?
If it is loaded and running then that side is OK. It seems to be a firmware breakdown in the scanner. Checkout the makers website
SOURCE: Unreconizable image
Try updating your scanner driver/software to isolate the problem. If same issue still occurring after uninstalling/reinstall, then source of the problem may be a CCD/lamp failure or some sort of dust, lint, on CCD causing calibration failure.
SOURCE: PF 1800 Scanner Silver--not scanning porperly
the scanner assembly is getting blocked somewhere internally due to dust collected in the assebly.or it can be due to any of the wire internally gone loose or cut slightly so this problem.
SOURCE: Just tried to install on laptop running Windows 7.
Yes a driver problem undoubtedly.. OK try re-installing..as Administrator and set to Compatibility Mode for XP SP2.. Win 7 is a PAIN with drivers...
SOURCE: Computer can't communicate with scanner.
Go to START menu click on devices and printer, then locate and click on add device, and follow the instructions.
Hope this helps you
I can not scan on iMac computer
