hi there.
try this.if this does not work go to the link at the bottom and see if it helps you out more.
Symptoms: When you open Google Chrome, you receive a pop-up error message that says "Your profile could not be opened correctly. Some features may be unavailable. Please check that the profile exists and you have permission to read and write its contents.
Problem Cause: You have corruption in your Google Chrome profile data.
Solutions:
Mac OSX
- Quit Google Chrome.
- Open Terminal.
- Change directory (cd) to /Users/{user}/Library/Application Support/Google/Chrome/Default
- Delete Web Data and History files: rm -rf History*; rm -rf Web\ Data;
- Start Google Chrome and the error should be gone.
Windows 7
- Open Computer.
- Navigate to C:\Users\{username}\AppData\Local\Google\Chrome\User Data\Default\
- Delete the file named "Web Data"
Windows XP
- Open Computer.
- Turn on Show Hidden Files and Foldesr in Folder Options in Windows Explorer.
- Navigate to: C:\Documents and Settings\{username}\Local Settings\Application Data\Google\Chrome\User Data\
Linux
- Open a shell.
- Change directory (cd) to ~/.config/google-chrome/Default
- Delete the file named "Web Data": rm -rf Web\ Data;
NOTE: If the problem repeats itself after every reboot, then there is most likely corruption is your user profile, so you will have to delete the profile and start a new one. In order to do that, follow the above steps, and replace step 5 and 6 with the following. Make sure that you backup your bookmarks before doing this, as they are a part of your profile and will disappear after doing this:
5. Locate the folder called "Default" in the directory window that opens and rename it as "Backup default."
6. Try opening Google Chrome again. A new "Default" folder is automatically created as you start using the browser.
your profile could not be opened correctly chrome Google Search
