Need to get access to and replace the Atheros mini-pci card. There are many screws on the back, labeled P3, P6, P9, etc. Do I have to remove all of these, and what else do I have to remove? Some of the P9 screws won't back out completely
Whoa!
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Put all of those screws back in. Tighten, but Do Not over-tighten.
3) http://www.irisvista.com/tech/laptops/Toshiba_Satellite_M55/laptop_motherboard_1.htm
Scroll down, click on the photo for Step 2.
Remove the screw for the Wireless Module Cover. (Wireless card)
Lift the cover up ON the screw side.
There are tabs on the other side. (Side facing you)
Close the small window. Now click on the photo in Step 3.
White cable (Wire), and Black cable. Make a small mark on the White wire, (Sharpie?), and near the terminal on the Wireless Module Card the white wire goes to.
Remove the screw/s, remove the Wireless Module Card.
Reinstall in reverse.
Regards,
joecoolvette
SOURCE: All for Toshiba Satellite P205-S6287 notebook
I am thinking that he just provided a set of drivers for this Laptop...
He simply put it there and said nothing...
SOURCE: atheros 5001 Mini pci lan adapter
If it is a LAN adapter, It is not a router.
A router enables you to connect several computers(256) with DHCP IPs
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: mini pci wifi for toshiba 1405 s-171 laptop winxp
As long as you have an open minipci slot, they should work. The antenna pigtails should plug into the card as well.
SOURCE: Atheros wireless problem
Ok, if your using Vista, what i want you to do is right click "computer" select "manage"
and then "device manager", then click on the + sign next to "network
adapters" and right click on the wireless network and "un-install" the
device, reboot the PC and wait for windows to detect the wireless
card and install the drivers for it, this will appear in the system
tray (bottom right hand side) when its done try to connect again
keep me informed please
regards and don't forget to rate us please
