Caller id is an extra feature on cell phones and it is not free. If someone is on your contact list and they are not showing up on the call screen, they could be blocking their number.
If you imported all your sim contacts &google contacts the phone might now hav some numbers duplicated or even tripled and then does not know which name to display when you receive a call from a number listed on multiple accounts. Go to your contacts & check all the boxes to display all possible contacts you hav- sim, google, phone, sd card, etc. Go through the list &try to take out all the numbers listed under more than one contact name! Even if it is the same name! It takes some time to sort out if you hav a lot of contacts, but that fixed my problem! Good luck!
Always happens. If there is no saved contact number there will show the number with 'Unknown' name. If you want to save the number with any name, then you might do that and after that if that number calls, it'll show the saved number.
Sometimes there are some incoming call that indicates only 'Unknown' with no number at all or '0000000000' that means callers have chose to hide ID or that is a VOIP call. Many operator permits to hide ID but not all.
Hi Bro. I have d same Problem since yestday.. It shows unknown number
for all d incoming calls even from d ones in Phone book. Did u find a
solution to this problem.. Please help me out on this. THANKS.
hi
try these codes
*#06# Show IMEI
*#9999# Show mobile Software Version
*#0837# Show mobile Software Version (instructions)
*#0001# Show Serial Parameters
*#9125# Activates the smiley when charging
*#0523# LCD Contrast
*#9998*228# Battery status (capacity, voltage, temperature)
*#9998*246# Program status
*#9998*289# Change Alarm Buzzer Frequency
*#9998*324# Debug Screens
*#9998*364# Watchdog
*#9998*377# EEPROM Error Stack - Use side keys to select values
*#9998*427# Trace Watchdog
*#9998*523# Change LCD contrast
*#9998*544# Jig detect
*#9998*636# Memory status
*#9998*746# SIM File Size
*#9998*778# SIM Service Table
*#9998*785# RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error
*#9998*786# Run, Last UP, Last DOWN
*#9998*837# Mobile Software Version
*#9998*842# Test ******** - Flash the screenlight during 10 sec and vibration activated
*#9998*862# Vocoder Reg - Normal, Earphone or Carkit
*#9998*872# Diag
*#9998*947# Reset On Fatal Error
*#9998*999# Last/Chk
*#9998*9266# Yann debug screen (Debug Screens?)
*#9998*9999# Software version
*0001*s*f*t# Changes serial parameters (s=?, f=0.1, t=0.1)
*0002*?# unknown Samsung's comand
*0003*?# unknown Samsung's comand
For Mobile phones SGH (R210, T100, A300...)
if Samsung code is in format *#9998*xxx#
try write in this *#0xxx#
SGH-600
SGH-2100
*2767*3855# Full EEPROM Reset (THIS CODE REMMOVES SP-LOCK! but also changes IMEI to 447967-89-400044-0
*2767*2878# Custom EEPROM Reset
Samsung mobile phone codes: Samsung E700
*2767*688# remove USER CODE and SIMLOCK
Samsung mobile phone codes: Samsung V200
Unlocking:
Power on the mobile phone without SIM card and type these codes:
*2767*63342# and press green button
*2767*3855# and press green button
*2767*2878# and press green button
*2767*927# and press green button
*2767*7822573738# press button
Phone will be unlocked, but all trims are reseted !!!
Mobile phone must be fully charged
Samsung mobile phone codes: Samsung S500
Unlocking
*2767*MVT# (*2767*688#) E2P MVT Reset
*#SIMLOCK# (*#7465625#)
This is because you have stored a contect more then once (like in sim as well in phone memory) in few mobiles when you store one numer two times it says on call unknown number
only store a number once ok
