E3 indicated. Stopped during rinse cycle. Water pump is working and empties, but spin cycle does not initiate. Checked electrical connections to motor all tight and drum turns easily. Understand that problem could be faulty Hall Sensor, but would resetting memory help? and if so, what buttons do you push?
SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
SOURCE: won't empty water slow spin in spin cycle
It spins, but doesn't pump
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
if this helps please vote a fix ya
SOURCE: My Maytag Neptune MAH4000AWW will not finish a full cycle.
I had the same problem. I called customer support and they gave me these instructions:
Shut off the water supply to the machine, disconnect the hoses from the back of the machine. Pull out the hose and pull out the little screens and clean them with water or soak in vinegar. I was skeptical but did this and the results were amazing. Apparently if the screens get even a little "gunked" up (my screens really didn't look that bad) the machine senses the change in water pressure coming in and shuts it off. Hope this helps!
SOURCE: shreiking spin in rinse cycle
Your pump is probably what's causing the noise . Usually the bearing starting to go out , causing the pump to freeze up , begins with this noise .
Testimonial: "Thought it might be a belt rather than the pump."
