e602-001/002/003/004 solution is turn off the machine after than
1-9 key hold & machine on 1 hour raning after same time display sow the downlod mode thn machine off/on
ok... turn dhcp on on the cannon... then turn it off and on... the cannon should pull the right settings... then turn dhcp off... and change the ip to the one you selected... all should be well after that... if it isn't... then you need to find the IP range of your router and get an IP address below it or above it.... say your IP address range is from 192.168.1.100 to 192.168.1.255 then you want an IP address below 192.168.1.100
