Paper not feeding.
Check
the following: Paper
type Load
up to Plain paper Approximately
120 Epson Bright White Paper 80 Epson Photo Paper Glossy 20 Epson Premium Presentation Paper
Matte 1 •
If the paper jams, do
the following: 1. Gently pull any jammed paper out from the output
tray or sheet feeder. 2. To eject the jammed paper, try turning the Epson
Stylus NX400 off and then back on.
this many sheets
Epson Presentation Paper Matte
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If that doesn't work and paper is stuck inside, turn off the Epson Stylus
NX400. Open the scanner, remove the jammed paper and torn pieces, close the
scanner, and turn the Epson Stylus NX400 back on.
SOURCE: Epson cx3800 paper feed problem
no you might have a paper jam somewere and mabe you ink rollers are dry you might have to tell the printer to to a pre test and clean and if there is a paper jam it should be a slot on the back by the roller should be a tap that shows the tollers look for a pice of paper jammed somewere in the roller you migh have to take the paper out to inspct it for a paper jam and if none mabe the print heads are dry and it dosent feed the paper then could be it ok clean the print heads tell the printer to to a roller clean and then after that if no paper jam no were try printing a page take all the paper out and feed it manually and if it prints then some printer want feed if you have filled the paper tray up try putting less and then try
SOURCE: white lines on printed photos Epson Stylus NX400
You need to clean the print head on the cartridges , please follow these steps\
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
SOURCE: epson c90 paper feed problem
Is the message general error? The problem is tchip. When turn on chip is recognized by printer, but when start to print, printer "read" some information from the chip. Here is the error. Some pin at the chip for redaing the existence of chip, other pin for reading the information. Check connector between chip and carriage.
SOURCE: I can't get my Epson Nx400 all in one to print on
I had this same issue and I got the printer to print on vellum but I can't say it looked all that great. But here's what I did. I went into the printing preferences and then to the maintenance tab. On the maintenance tab you'll see an option for Printer and option information. Click on that and then you will see a little check box down at the bottom of the pop up and it says Thick paper and envelopes. Put a check in the box. Click ok and then it should print on the vellum for you. Make sure you put the vellum in the printer the right side up (front side) because if you don't it will print all messed up.
