classic 3110 just went blank. can still make calls display only not displaying. classic 3110 just went blank. can still make calls display only not displaying.
Screen went blank on nokia 3110 classic totally out of the blue,now when switch on phone nothing on display except you can still make calls only you are blind.calls can also be recieved.Screen went blank on nokia 3110 classic totally out of the blue,now when switch on phone nothing on display except you can still make calls only you are blind.calls can also be recieved.
You can't post conmments that contain an email address.
many reasons are major cause for no display,blank display,scrambled display. In samsing champ duos c3262 no display problem terouble shooting.first connect with charger no charging logo on screen.open your cell phone and clean pcb and lcd connector with corbon tetra cleaner(ctc)dry normal.problem not solve then try seen lcd with lamp if display is shown but no light make light jumper or change lcd.lcd ok and new 100%working condition please be care fully check lcd connector.no display no luck final heat or replace display controller ic.
here is the light ic jumper if your lcd is black and now lights.
click on link for jumper ways by image. Samsung champ duos c3262 no display jumper Phonetolls
Hi.First change the LCD and try if the problem still persist Change the Display IC or make jumper.You can see the details from this link Nokia 3110c Display Problem - GSM-Forum.Good luck.Thanks for visiting fixya.
Most of this problem can solve by changing of strip.But sometimes in the condition like water damage you can change the display IC (Filter)...it is available in the mobile shop.Or you can use this Jumper Tricks
6085 display jumper solution.
Good luck
3110 display ic problem
