sree Posted on Aug 17, 2012
ERROR E3 IN HP LASERJET PRINTER M1136 MFP
  • Anonymous Mar 18, 2014
    How to take a scan from my laserjet m1136 mfp printer
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Apr 06, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
8507
Points
15
ERROR E3 IN PRINTER DISPLAY
  • Anonymous Apr 06, 2013
  • vikas visaria
    vikas visaria Apr 21, 2016
    Now No need to Buy NEW, NO need to refill or change any parts of TONER CARTRIDGE... BECAUSE Now toner Cartridge @350/- with unique scheme in MUMBAI only
    save your printer's life.....
    .... 9987779811
    lasertoner.in
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 06, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5907
Points
My printer Laserjet M1136 MFP display show HP
5 Related Answers
Anonymous
  • 495 Answers
  • Posted on Apr 17, 2009
SOURCE: Scanner Error 12
SCAN ERROR 12, IT'S A MECHANIC PROBLEM. YOU MUST CONTACT A TECNICIAN.
Anonymous
  • Posted on Jul 26, 2010
SOURCE: error 79 hp laserjet m2727nf mfp; error 49 hp laserjet m2727nf mf
Bueno, el error 79 en mi caso se presentó con el servidor de impresion, tienes que limpiar los trabajos en cola y luego reiniciar la impresora.El error 49 indican que es con un problemas de fax o con scanear en Mac OS X, en todo caso hp support tiene los pasos a seguir.
Anonymous
  • 37 Answers
  • Posted on Jun 15, 2009
SOURCE: error 6 hp laserjet 1120 mfp
The problem is that the motor that drives the scanner probably overheated and because of the cheap plastic that HP used it melted important points that the motor relis on...so - remove the glas of the scanner(there are some screws - one of them hidden under the label of the panel,unhook the interface cable of the panel).Now you should see the scanner - flip it over and look at the motor exle and the gear that it should mesh with - they are not aligned at this time.To fix it i used 2 small pieces of plastic - sticked it under the motor so that it can not move in vertical direction anymore. Simply this is the solution that i used and it works just fine :) If you have any questions dont hesitate to contact me. [email protected]
Anonymous
  • Posted on Feb 04, 2011
SOURCE: SCANNER ERROR 20 of HP LASERJET M1120 MFP
PRINTER: HP DESKJET M1120 MFP DISPLAY SCREEN SAYS; "SCANNER ERROR 20"...
ANY IDEAS HOW TO FIX?
MANY THX!
Anonymous
  • Posted on Apr 19, 2010
SOURCE: SCANNER ERROR 12
it is a physical brocken piece that supports scanner mechanism.
if you open that plate /scanner mechanism and if you drill that plastic sheet and try some manufactureed alluminium or metal projection and place it in the hole drilled by you and put washer and screew so that that supports ;the scanner mechanism and your scanner /printer works . the scanner mechanism may costs you around 3,000-00 rupees.
Hp m1136 mfp laserjet printer print blank pages when i copying....
Check your toner cartridge first.
There is more than one cause for this problem. It could also be your transfer roller that needs to be replaced.
Or it could be the scanner that has gone out.
Are you getting an error code?
How remove e3 code in hp leazerjet m1132
http://h30434.www3.hp.com/t5/Printing-Issues-Troubleshooting/error-E3-on-my-HP-laserjet-M1132-MFP-printer/td-p/3914982
HP PRINTER M1136 ERROR CODE E3
P{lease visit the following link on the HP website for suggestions on how to fix this issue.
error E3 on my HP laserjet M1132 MFP printer
Good Luck!
Rich Lilja
2answers
ERROR E7 IN HP LASERJET PRINTER M1136 MFP
HP M1136 printers doesn't have E series errors, pl chk
2helpful
2answers
18helpful
2helpful
Hp laserjet m1136 mfp e8 error
printer & cartridge refilling issues in bangalore kindly call 9448311575
17helpful
What is meaning of E8 in HP Laserjet M1136 MFP
I have face a problem in laserjet m1136 i.e. show a e8 error .how can i free it or remove it..
5helpful
k24674
Grand Canyon Tech
Grand Canyon Tech
