Hi, i have a kenmore 80 series washing machine. as of right now it will fill up with water, agitates, it will click 3 times and completely stops. the next cycle is the draining part and it won't drain. thanks alot!!!
Hi
First
make sure that nothing is blocking the drain pump assembly located inside the
bottom of the unit, after this test the lid switch assembly, you jump it to
test it. If the lid switch is also fine then the control board should be
replaced. Hope this helps...please post back for further assistance.
Daniel
