My washer filled with water and now wont do anything. I check for lid problems and that is not it. The water wont drain and when I pull the nob out to start it it sounds like power is running to it but nothing is happening. I plugged my dryer into the outlet to see if that was the problem and my dryer works fine. I tried running it on regular, delicate and wrinkle free settings and it didnt work on any of them. I tried running it on the spin, rinse, and fill cyles and nothing happens. Any ideas?
Check the back of the lid their is a litel plastic button to make sure the lid is closed see if not broken or stack
or see if drain pomp V belt is out of place or broken
this is the simple way
Hi, I have a maytag washer #HAV3460AWW. Not sure if you have the same one. But when I had my warranty did have a tech come out as it filled but stopped doing it's thing. If you open the panel there is a tube runnign along the side ..that comes loose alot w/off balance spinning. The tech tightened the clamp and it worked!
I have an SAV2655AWW.
I just started a wash cycle and the water level filled to the normal fill point and it stopped. Then everything stopped.
No sound on any dial position. Tried opening and closing lid. Checked power circuit with volt/ohmn meter and voltage is normal.
Does the lid switch have a fuse on this model?
Do you think it's the timer?
Thanks,
Richard
Same as above only when I plug the power cord into the wall and pull of the knob to operate the washer, I smell this electrical burning odor.
Any ideas?
