Garden Logo
Anonymous Posted on Aug 18, 2012
Kill switch on stihl FS36 wont work
Kill switch will not shut off the engine. How do I get in to fix this problem.
Plink-plonk
Level 3:
  • Stihl Master 1,807 Answers
  • Posted on Feb 27, 2016
Plink-plonk
Stihl Master
Level 3:
Answers
1807
Questions
Helped
817755
Points
15648
Probably a faulty earth cable from the switch to the ignition module
3 Related Answers
Anonymous
  • 1206 Answers
  • Posted on Mar 09, 2010
SOURCE: My kill switch on my troy bilt TB425CS doesn't
its just a switch that grounds out the coil remove the switch and replace it with any that connects two wires to currentso when on the two wires are connected that should fix it if not follow the wires to where they end and check the connections.
Anonymous
  • 63 Answers
  • Posted on Jul 24, 2010
SOURCE: kill switch on my Stihl 85 trimmer will not work
i am guess ing you have checked the contacts directly under the switch I had the same problem and i cleand the whole lot and it worked rust was a problem as well there
rycgl
Roy Cagle
  • 1545 Answers
  • Posted on Mar 15, 2011
SOURCE: How can I trouble shoot the kill switch on a echo
Check the kill switch terminals with a continuity tester (small multi-meter will work). If the switch is Ok and there is no spark, take off the engine cover and check the "air-gap" between the magnets in the flywheel and the ignition module legs.The closer the better, but you want about a ,008-.010"gap there...about the width of a standard sized business card. Metal feeler gauges "stick" of course to the magnet area in the flywheel and throw off clearance sensitivity. Try it with a business card. If not in range, then loosen the coil screws, double the card over, and let the magnets pull the coil legs into the card...retighten screws and check for spark.
1helpful
Why does my Stihl FS220 have 2 thin wires to the coil? I noticed one was disconnected while replacing the piston, I fitted it in to the gap in the spade terminal going onto the coil, now no spark.
One wire is ignition module kill (primary of a magneto) and the other is ignition module frame (engine block).
The two wires run separate to the kill switch which is a momentary single pole.
Kill switch is broken on stihl 08s, can it be bypassed
Yes it can be hard wired to bypass the kill switch but then how do you kill it. So no donor bypass it
2answers
How do I shut off my 017 stihl
If your kill switch doesn't work, turn the choke on until the engine dies. Be sure to turn the choke off afterwards so the engine doesn't flood. IF you are mechanically inclined you can probably fix the kill switch yourself. otherwise you can use the choke as described, it won't hurt anything on your saw, I have a Stihl 011 with a bad kill switch that I've been using for years.
Sep 30, 2014 • Garden
Stihl FS 55 will not shut off
I have seen the wire work itself or break off the ignition module and I have replaced several of the actual kill switches. Check the wires from the switch to the ignition module first and if they are good go to your local STIHL dealer and ask for the switch. The switch part number is 4229 430 0203
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Jan 15, 2013 • Garden
Where do I attach the stop switch wire on a Stihl FS36 weed trimmer?
one end goes to the switch the other end goes to the ignition module
Having trouble shutting off Stihl chainsaw
the kill switch wire might have broke between the coil and the switch
My stihl fs36 Whippersnipper continues to flood what is the cause
needs a carb kit with needle valve $20 at a small engine store
Kill switch not working
Brand new should be warranted; take it back to your dealer. Attempting to repair it yourself may void your warranty. Lou
Sep 02, 2009 • Garden
1helpful
Kill switch on Stihl BG 75 leaf blower not working
when engine cool,, spray wd 40 into the switch and work it a dozen or so times and clen it out
Aug 12, 2009 • Garden
Bike wont kick over
do u have any spark at the spark plug. When the kill switch is faulty it won't give any spark try disconnecting. sometimes this kill switch grounds itself or the contacts stay closed. For it to have sparks contacts should be opened. This kill switch grounds the coil so the engine stops running
Top Stihl Garden Experts
Thomas Perkins
Thomas Perkins
Kardoc
ADMIN Andrew
ADMIN Andrew
Are you a Stihl Garden Expert? Answer questions, earn points and help others
