SOURCE: I have a maytag 7806 ACE 1. water is leaking from
sounds like you have a belt slipping ,try repositioning the basket sometimes its a lil off .CLOWNY DAGGERS
SOURCE: maytag LSG 7806 Electric Dryer doesn't heat up how
Hi, If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat. check out this electric no heat tip... heatman101
heatman101
