SOURCE: Our Sony Bravia tv picture keeps going light dark
I have Sony KDL-32XBR9 and I have noticed a similar problem. When the picture is showing mostly black, for example during the ending credits of a movie, the TV will further darken the display. Once the picture lightens back up, the TV will adjust the brightness of the display back to normal. I just called Sony customer support and they indicated it was a firmware problem and they will be sending a USB device in the mail to update the firmware. Hope this helps.
SOURCE: what to do if my sony bravia 46 inch gets dark on the right
Your inverter or cfl bulb is out on the right side.
SOURCE: have a sony kdl-46xbr5 bravia
I need bit more detail about dark and cloudy screen at right side.
Does this change in screen start from center part instantly like it divides screen in two sections or screen gets darker gradually?
Thanks.
SOURCE: My 46" Sony Bravia lcd has a dark patch in the
most likely a LCD panel failure suggest calling sony customer support and see about repair accomodation 1-800-222-7669
SOURCE: 52" Sony Bravia TV has a thin Blue line down left
A line on an LCD screen can be cause by the screen itself going bad or the T-con board. The T-con board the attached to the screen on the backside and covered by a heatshield. If you get teh part number from it you can find it online from one of the many retails that might have it. Like www.interliquidparts.com
