Question about Whirlpool LSQ9544K Top Load Washer
Wash water does not drain and doesn't spin
Wash water remains in the tub and no sounds start as usual when draining starts. I've tried in all cycles and no drain or no spin. I've unplugged, waited a minute, plugged back in and opened and closed lid as one online support said, but I don't think my washer has this feature. It was purchased in 2003. LSQ9544KQ
    Top Expert:
  • Whirlpool Master
  • 6,289 Answers
You have one of the best made washers in your direct drive Whirlpool made washer. It sounds like your lid switch is bad. A fairly inexpensive repair.
Posted on Oct 24, 2017
  • Whirlpool Master
  • 18,165 Answers
12 years is a good run for a washing machine. I get 10 to 12 on my Whirlpool units.
    Top Expert:
  • Whirlpool Master
  • 55,370 Answers
Your washer is suffering from old age.
5 Suggested Answers
Anonymous
SOURCE:
Anonymous
  • 97 Answers
SOURCE: JUST STAYS IN CYCLE AND DOES NOTHING
hiya
the filters are usually located behind the plastic kick plate on the front of the machine or behind a flap also on the front of the machine.
if the filters are all clean then it maybe that the motor brushes are worn down and so the machine wont spin
it could possibly be a faulty pressure switch not telling the machine that the water has completely gone and again wont spin.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Posted on Aug 03, 2008
Anonymous
  • 639 Answers
SOURCE: whirlpool washer not spinning or draining
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
Anonymous
  • 8 Answers
SOURCE: Washer will not drain or spin after wash cycle
Probably your filter or drain pipe is blocked. You have to clean out.
Click on your model number (below FIXYA) on this website, type in & search. You will get a shortlist; click on your model, below the page you will get Manual/Guides. Click on the blue, you have your manual on line. If available that is............
Posted on Feb 22, 2009
localwonder
Michael Masters
  • 6784 Answers
SOURCE: The washer will not agitate or spin. It does drain the water
Hi, this can be two issues here. Number one would be a busted belt. The next issue would be a drive assembly failure. this consist of the clutch and gear case(transmission) assembly. I would check these areas out. you will find the problem here.
Posted on Mar 22, 2009
My frontload washing machine fills water but then it will not turn.
I would check the motor. Sound like it may be at fault.
Nov 04, 2012 | Washing Machines
Water did not drain
see the causes and fix it. God bless you
If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Sep 22, 2012 | Kenmore HE2 Plus Front Load Washer
Washing machine does not empty
see the causes and use the common sense, God bless you.
Sep 19, 2012 | Ariston Technologies Washing Machines
I have a Whirlpool Ultimate Care II washing machine (model LSN1000JQ0). The washer will fill with water and begin to agitate. Shortly after it will stop and will not drain. I've cleaned all hoses
see the next steps and use the common sense: God bless you
Aug 01, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
What can I do to get my WP Cabrio washer to drain & spin?
Your drain hose has to be higher than the water level in the tub, almost up to the top of the tub
Dec 30, 2011 | Whirlpool Cabrio WTW6600SBK
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 26, 2011 | Maytag Washing Machines
Hi, My Hoover 600MB top loading washing machine is approx 8 years old. Recently it has occassionally not fully spun out - clothes still wet at end of cycle. Now it also often doesn't agitate - just...
Have a look for coins etc stuck in the drain pump or the tub outlet hoses especially where they fit onto the tub. If a coin or other foreign material blocks the water flow when draining , these machines wont spin properly.
Jul 26, 2011 | Hoover Washing Machines
My washing machine won't spin. i've cleaned the water hose filter and the pump filtre.
Hi eddyloz2000,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 18, 2011 | Washing Machines
Is leaking water at the back and running in the floor the hoses are tight drain pipe is in right
Here's what I've seen. Water will be full, machine goes to spin/drain and expects the water to be pumped out as predicted. If pump is clogged, the pump cannnot pump out water quickly enough and the spinning causes the water to spill over the back of the tub, between the tub and balance ring. The balance ring is never sealed tightly to the tub so water will get through. Fill the basket with water, extra high, hold lid switch down, and see if it drains out fast enough so water doesn't spin out. If this is the case, pull pump, dislodge debris.
Oct 02, 2010 | Maytag Washing Machines
Whirlpool LSQ9544K Top Load Washer Logo
83 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
