Meade TeleStar DS-2114ATSA Telescope Logo
Posted on Dec 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What else do I need?
I just was given this Meade Telestar mounted on a tripod. The only information on it is (D=100mm), (F=1000mm), (F8.8), Telestar.
Please tell me what I have and what do I need to get this to work. The only items missing are the eye pieces and I don't know what else.
Thanks
Bob in Florida
  • Innstep Jan 12, 2009
    I have a similar problem with an Helios Telescope that I am currently "storing" for my son-in-law, he has lost Interest in the stars as well as the Users Manual.
    The only info on the instrument is "HELIOS TELESCOPE D=114 F=1000mm Coated Optics". There are two eye-piece lenses: H20mm and H8mm and a 2x Barlow lens.
    Can anyone HELP. I am a total novice and even having problems geting it to focus on the moon.
Anonymous
Level 2:
  • Expert 112 Answers
  • Posted on Dec 26, 2008
Anonymous
Expert
Level 2:
Answers
112
Questions
0
Helped
70395
Points
140
Give meade a call @ 18006263233 thats where you should start....good [email protected]
Your website no longer contains the manual for the Telestar 114AZ model and I'm in desperate need of it's use.
This is a small reflector style telescope. Any of the REFLECTOR manuals has enough information to assemble and use this telescope. Look under the REFLECTOR heading for one that is similar to your scope.
http://www.meade.com/manuals/index.html
2helpful
Hi, I have a meade lxd55 tripod (with 8" discovery newtonian mounted on it). 2 of the 3 leg braces at the bottom that also hold the eye piece tray have broken. I need to replace 2 or all 3. Can I get...
Sometimes you can find these for sale at these web sites--
Sometimes--
http://shop.telescope-warehouse.com/
and here:
http://astronomy-mall.com/astro.parts.outlet/
You might try calling Meade directly:
http://www.meade.com/support/index.html
I need to find an Eyepiece for my grandsons TeleStar 60AZ-A
Most telescopes use a standard size for eyepieces (one and a quarter inches outside diameter) and if that is the size of the mount in your scope, you can use any that fit. If you do a search on Amazon, you will find hundreds in this size, many of them branded Meade. The other dimension specified will be focal length. 5mm will give high magnification (but dimmer and harder to use) while 20mm will give lower magnification with brighter image and less fiddly focus.
I have a Meade telestar 114mm reflector. F=1000 f/8.8. There is what I believe is a correcting lense element located at the bottom end of the focuser tube that has come loose. I need to know which side of...
That is called a diagonal.. It slips all the way into the focuser, then the screws are tightened to hold it there.
The eyepiece then goes into the diagonal.
I was given a used telestar telescope by meade that has no manual. I have never used a telescope, what can i do?
http://www.meade.com/manuals/TelescopeManuals/Telestar/TelestarRB60.pdf
Well,you didn't give me much to go on. But here's a manual for a telstar.Just maybe you got lucky and it's yours.Next request for info try to give a model # for more accuracy.Take care!
Jan 17, 2010 • Optics
3helpful
Manual For Telestar By Meade
Here are all of Meade's manuals ----
1helpful
What have I got here?
Buy an eyepiece--
Here are all of Meade's manuals-
and here are on line retailers that sell eyepieces--
http://www.optcorp.com/
http://www.telescope.com/control/main/
http://www.agenaastro.com/
2answers
Meade telestar D=130 mm F=1020 mm
rosores: make sure that the DEC clutch is not locked, and that the screw on the side bar is loose.
before pointing it upwards. or damage may occur.
STH55
Top Meade Optics Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Meade Optic Expert? Answer questions, earn points and help others
