Need instructions badly.
I just picked up this watch. Setting it is easy. Hold down the button marked "RESET" (lower right) until the numbers start blinking. Hit the "MODE" button (lower left) until the the settings you want to change are blinking. Hit the "ST/STP" button (upper right) to change that setting. Keep on hitting these two buttons until the settings are as you would like them. Hit "RESET" button to finish. So, to change just the day, I would hold down "RESET," hit "MODE" four times, hit "ST/STP" until the date is correct, hit "RESET" to save.
Thanks so much. It doesn't give that info but based on seeing exact pictures on E Bay I believe it is the Ottimo Solar Powered Billboard sports watch. There is a button for light which illuminates it, one for mode that displays various things but the stop watch function is the only one I can figure out, another for Reset that does nothing and one for stop watch. The month and date and time scroll across the face but I can't change it to the right day, time or month. I have 2 with the same problem.
Ebay efers to it as the Ottimo "NOS".
Can you upload exact make, model, ref. number and,if possible, movement number? Without this it's allmost impossible to find the right instructions.
