Question about Hitachi 42HDF52 Television
Hitachi Plasma will not remember what input to watch tv on
Ok this is a Hitachi 42hdf52 plasma tv purchased around August of 2005. When you turn the tv off with the remote control or on the front panel and leave it off for over about 5 minutes and then turn the tv back on.........it loses its input selection and you must push the input button several times to set it back to where it was. The default seting is composite video input.......well thats just the one I dont use. So everytime I want to watch tv I turn the tv on and then have to push the input selection button 4 times to select the right input to watch tv. The Directv box is never unplugged or turned off and the tv is always plugged in and turned off by remote control. I use a red,blue,green cables to connect between the directv and the tv......directly.
TURN THE TV OFF AND LEAVE OFF. TURN THE CABLE ON AND TURN THE CABLE OFF. LEAVE THE TV ON.
Posted on Apr 11, 2010
6ya staff
SOURCE:
Hitaci plasma 42hdt20 remote will turn monater when red standby light on
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
http://electro-medical.blogspot.com/
Dec 25, 2016 | Hitachi 42HDT20 42 in. Plasma Television
Hitachi Plasma TV Model PD32-A3000/AVC-A3000
Check for any fuse blown also, Otherwise it s a power supply fault.
Jul 30, 2008 | Televison & Video
Inputs will not change with remote with my Harmont reomte
Hello
It will be difficult to match any other universal remote with this model Hitachi set. You have to get the original remote control to select all the functions with this TV. If your original remote control doesn't work at all, just buy a new one. You can get it from the authorised service center for Hitachi at your town. OK.
Nov 04, 2011 | Hitachi 55HDS69 55 in. Plasma Television
I HAVE A 50 INCH PLASMA TV THAT WAS GIVEN TO ME WITH NO POWER PLUG OR REMOTE . I WENT AND BOUGHT A POWER PLUG ,PLUG IT IN AND NOTHING HAPPENED . DO I NEED THE REMOTE TO OPERATE THE TV ON AND OFF/
Hi
If the set doesn't power ON, what is the use with a remote control? If it power ON properly, the power indicator light at its front panel will light up. Look for this. If it doesn't, make sure that you have got a set which has to be repaired. If it does power up, just get a remote control to operate it. OK.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
I have a hitachi 50 "plasma that was given to me
First do you see a light indicating that the TV has power? There are two power buttons on the TV (the main power and the regular power button). The red standby light will light up when the main power switch is on. This indicator is just to the left of the remote I/R sensor. You can find the main switch on the bottom front of the tv (it is under the tv forward of the stand). Turn on the Main power if it is not on. Then try the power button on the control panel of the TV again.
Does the standby light change color or blink? (Red is standby, orange is power savings (no signal), blue is on.) If the main switch is on and the standby light doesn't come on, the TV has a problem at the power supply. Try unplugging the unit for a bit (at least 30 seconds) and then plugging it back in. This will reset the internal circuitry. If you see a blinking light, then the TV is reporting a self-test failure. I do not know the codes for this model Hitachi Plasma TV.
The manual for the Hitachi P50H401 TV is available from Retrevo: http://www.retrevo.com/support/Hitachi-P50H401-TVs-manual/id/1233ci869/t/2/ . You will need to enter a code to access the pdf.
I'm assuming you don't have one of the special versions that were intended for large audiences that were only controlled by remote (no control keys on the front of the TV). Remotes.com has the original remote or a substitute remote if you need it. See http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13104063628240&smodel=P50H401&brand_pn=HITACHI_P50H401 .
I hope this helps.
I have a hitachi 42hdf52 and i was watching it when i heard a loud pop and my screen went black my green power light remained on untill i tried turning the unit on and off then it was tottally dead. Any...
Ur tv power supply board is dead.Replaced the power supply board,ur tv power will return,and the tv will work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 21, 2010 | Televison & Video
Help hitachi p42h401 input display does not fade on its own
easy one
you need the tv remote to turn off the display
usually marked i or somewhere in the tv sub menus
or download an instuction man for the tv if you have lost it
Jun 01, 2009 | Hitachi P42H401 42 in. Plasma HDTV
Hitachi 42plasm tv
take it back to the store, make sure the power cod is in all the way and you dont have it on a switched outlet, see if you can see any cracks or if the box was damaged/
Dec 08, 2007 | Hitachi P42H401 42 in. Plasma HDTV
Televison & Video Logo
640 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
