The Photoconductor Kit designed for use with Lexmark E230, E232, E232T, E238, E330, E332, E332N/TN, E240, E340 and E342. Yields 30,000 pages.
Have you printed 30,000 pages on this unit? If not perform the following reset:
Procedure for E-232 is:
1. press and hold Start
2. turn on the printer
- this is service mode -
- by pressing the Start you can print Printer Settings Configuration sheet -
3. press and release Cancel 4 time
4. Press and hold Start while all lights start cycle
5. press and hold Cancel untill all the light cycle
6. turn the printer off to exit the menus
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Solution:
? Press continue button to clear message and continue processing job.
? Remove the toner cartridge. Gently shake the toner cartridge from side to side and front to back several times to redistribute the toner, and reinsert it. Repeat this procedure multiple times. If the print remains faded, replace the toner cartridge.
For further assistance, please contact Lexmark Technical Support
After installing a new cartridge and the blinking light is on Toner Low, it means that the photoconductor is almost full and should be replaced soon. Press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, replace the photoconductor kit.
For further assistance, please call Lexmark Technical Support.
The light is second to the right is Toner Low. If ! and toner low displays a flashing light it means that the photoconductor kit is full and must be replaced. The printer will not print any more pages until the photoconductor kit is replaced.
Press and release Continue button to print a photoconductor kit instruction page. If the light is still blinking, replace the photoconductor kit.
