1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Free Games for PC You can Play and Run Games on your PC Computer
SOURCE: charging problems
have you tried your dads battery in your phone it sounds like the battery is dead if your charger works on your dads phone then you know it not the charger the chances are it is the battery it would only be the phone if it has been dropped or got wet if this hasnt happened then the problem is the battery if your dads battery is the same then try charging his batt through your phone that way you would know if it was phone or battery.
If you take the phone into any phone shop they will test the phone and battery for free for you they can try the battery and also try a new battery in your phone and they will tell you if it is phone or battery but from my experiance it is going to be the battery let me know how you get on ok
I had the same problem. Take the back off your phone and push down on the battery (the same way you would to install the sim card) so it slides down to make better contact with the battery contacts. I had the same problem and ended up taking a thin piece of paper and sliding it between the battery and the tab at the top of the phone that holds the battery in tight to the contacts.
SOURCE: Motorola Razr v3i does not charge. When you put
the only things i can think to tell you are
send it in for repairs,
or get an external charger.
the charger would probably be less expensive
SOURCE: my razr won't charge.
The inside pin may be broken. Try wiggling it. If not you may need to get a new phone. Happened to me too.
